Portable EQ? - Battery Power & SMALL
Old 10th December 2011, 03:00 PM   #1
midside is offline midside  United States
Default Portable EQ? - Battery Power & SMALL
I'm looking for a very small portable EQ that I can use with some small powered monitors. I am running the monitors with (1) lithium battery pack.
The battery is (3) 3.7 volt cells and functions in the range of 9-12.6 volts.
My playback source is a recording device that does not have tone controls
for playback review.
So, I'm basically looking for a really small EQ so I can tweak my playback
mainly to augment low bass.
I plan on powering it with the same battery that is running the speakers
and not looking to bring another battery/charger along.
I have seen a little info on the Behringer FBQ800 & Samson S Equaliser Mini.
Looking for a plug and play option, not looking to build.
Anyone have any input?
Many thanks!
Old 12th December 2011, 12:35 AM   #2
Well, looks like both the EQ units above run on an ac power supply and I need
something that will run off a battery without modifications.
Surely someone here must have an idea?!?
Old 12th December 2011, 01:59 AM   #3
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
use EQ's designed for car audio?
Portable EQ? - Battery Power & SMALLHide this!Advertise here!
Hi-Q speakers, small boxes, DSP-EQ & phase Horn_aficionado Full Range 12 28th September 2010 01:10 AM
Small and portable headphone amp Crisis firefart_1st Headphone Systems 15 26th May 2010 08:24 PM
Powerful small/thing portable speakers? (battery powered?) Anirak Everything Else 2 24th March 2009 09:29 PM
Small Portable Speakers and a T-Amp guitarobert Full Range 2 24th January 2008 06:40 PM
Battery powered portable Class-D mono amp >50W RMS tonfelix Class D 1 29th April 2006 02:08 PM
Copyright ©1999-2017 diyAudio
