| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
A friend of mine built an attenuator based on LDR design. I noticed that L+R channels are imbalanced. when the pot knob is turned up, it starts from R channel +5dBFS louder then L channel (minimum), but when knob turning up, the imbalance gets smaller and smaller, until around -20dbFS (around middle) it's almost perfect, then Left channel (when turning up) became louder and louder - up to -5dBFs, and it's almost perfect when in full 'open' position. I was told it is just a problem with LDR and it possibly can't be resolved, but I remember reading some audio purist using LDR att. and I don't think they wouldn't notice a 5dB difference between channels, so I presume it's possibly to have it ideal (0.1dB - I can live with, 0.2dB - would be maximum) Could you please help me - what could cause this sort of problem ? How to resolve it ? Is it simply swapping a pair of LDRs or sth else ? I really appreciate your help, here - thank you in advance If LDR design is not perfect and it's very difficult to find pair of LDR with 0.1dB difference - could you please advise me, what type of passive att. would be good ? - in a 'human - 99%' price range |
#2 | |
Personally, I would go for something like an ALPS motorised pot every time.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 | |
#4 |
The ALPS is the classic quality audiophile pot that has been used for decades, for example
ALPS|RK27111250K|POTENTIOMETER, 50K | Farnell United Kingdom
#5 |
Thank you for your input, so do you think ALPS is 'close' with sound quality to ldr ? if yes, then maybe I'll drop the idea with ldr....
I dunno I am not constructor myself, my knowledge in the area is minimal..... |
#6 |
I can't really comment on the LDR type control for sound quality as I haven't built one.
The ALPS has always been the "Gold Standard" for quality attenuators and I and countless others (manufacturers and diy) have never had a problem. The LDR "Lightspeed" is an intriguing concept but the wide tolerance of the LDR's to me implies close channel matching will be difficult without a lot of individual tweaking and compensating.
#7 | |
thanks for your input, do you think ALPS is as best as it gets ? or it is a chance to invest a bit more in pot and have better sound ? what about goldpoint or this : HiEnd attenuator 48 steps silver passive preamp Caddock | eBay thanks in advance for help |
#8 | |
Why not post on the main Lightspeed thread as you can get advice from those who have built the thing, know the circuit well and don't need to imply its qualities or limitations? FWIW, my experience with both the Lightspeed and The Lighter Note is that they knock spots off switched attenuators when it comes to preserving detail. Though I suspect that even I would notice a 5 dB swing, I haven't experienced balance issues. |
#9 | |
I do not imply it's quality or/and limitations, I am just asking, I need device with up to 0.2 dB imbalance LDR l+r imbalance - YouTube if you watch this vid, you'll notice it's not about constant difference L/R channel, but this is inconstant, permanently changing... I don't know myself which way to go....I'd like to utilize ldr design, as it seems for me almost ideal for audio purist, I am seeking answer, could anyone who owns ldr design can check if their box is accurate ? thanks for input |
#10 |
just to add- on video ldr was fed with 1kHz looped wave
| Preamp: Comparing LDR and buffered LDR | Dr.H | Analog Line Level | 7 | 5th October 2011 01:29 AM |
| 24 step ladder att - question | sparkle | Solid State | 8 | 14th January 2009 02:02 PM |
| Att Thorens 126 Mk 2 | retrodisko | Swap Meet | 0 | 17th November 2006 07:04 AM |
| Att: All Laser Heads a little present for you | georgehifi | Digital Source | 1 | 15th March 2006 01:48 AM |
| Att:Uffe Nisbeth,Steven wegmann | tone | Swap Meet | 1 | 31st March 2003 06:02 PM |
| Page generated in 0.12797 seconds (79.97% PHP - 20.03% MySQL) with 11 queries |
