Schematics needed for 3V 1KHz Sine wave generator
Old 15th November 2011, 03:38 PM   #1
graygem is offline graygem  United States
Default Schematics needed for 3V 1KHz Sine wave generator
Would like a 1KHz sine wave tone generator that would run off a 3v rechargeable lithium coil cell battery. All the ones I found were for 9V plus. The idea was to make a USB chargeable tone generator using a New Age USB enclosure Any help would be appreciated.
Professional Newbie.
Old 15th November 2011, 05:56 PM   #2
firechief is offline firechief  United States
firechief's Avatar
I think that your are not getting replies because the question is so open ended. I would ask -- do you really only want only one frequency? What is the desired output level and into what impeadance? Does it need to be a spectrally clean signal? Does it need to be frequency stable and accurate? The first thing that comes to mind is a one transistor LC based oscillator perhaps with a buffer. Of course the physical size of the L and C are going to make it hard to get into any of those boxes. The other approach if you need accurate frequency is to run a crystal oscillator at some higher frequency and then divide it down, but that involves a flip flop or some such which sill output a square wave and then you could filter out the harmonics,. I would consider a small microprocessor like a PIC. There are probally some that could be programed to do the frequency division with onboard logic. All of these options can be designed to operate off of your 3V, but you have 5V when connected to USB. Do you mean that this should be able to operate stand alone after charging? In short, tell us more about what your are trying to acconplish. I must be bored to write a reply like this.
"You can keep your insurance baby nothing is guaranteed" -Tom Petty
Old 15th November 2011, 06:09 PM   #3
firechief's Avatar
Oh Yea Check out Audio Test Oscillator
Rod Elliott has some nice clear information on the subject.
Old 15th November 2011, 06:23 PM   #4
simon7000 is offline simon7000  United States
http://www.discovercircuits.com/Andy...oscillator.pdf
But use a rail to rail low power op amp. Also you will need an output coupling capacitor.
http://www.ti.com/lit/ds/symlink/opa2342.pdf
Old 15th November 2011, 06:34 PM   #5
jcx is offline jcx  United States
DAP, the ubiquitous portable "mp3" players are what comes to mind 1st for me
they already have usb, battery charging, user interface, can hold quite a few more test waves than just 1 kHz sine
Old 15th November 2011, 07:08 PM   #6
firechief's Avatar
Now that is a good idea.
Old 17th November 2011, 12:30 AM   #7
Yes, I only need the one frequency, 1KHz. It is for a tone test on induction loop equipment. We've tried using an MP3 player but the conversion from the test CD changes the tone so it is not an accurate reproduction of the 1KHz tone. I have used my iphone but I really don't want to lend that out, plus the output is not quite high enough before distortion kick in. My thought was to have a tone generator that could easily be recharged through USB. When it's charged, it could be taken to the site for test. I could be easy on myself and build a 9v tone generator, but what's the fun in that.
I have already been to Mr Elliot's pages.
I Will look into Simon7000's links, thank you.
Old 17th November 2011, 12:52 AM   #8
Default if you're fixated on hacking analog, fine - but the DAP will be easier
I'd be suprised if mp3 really botched a single sine
but even if that's true you can still play .wav/flac on some players, even more if you include those you can RockBox
if you need a little more V then Radio Shack has audio isolation xfmr that can be wired for 2x (auto xmfr mode)
Old 18th November 2011, 05:05 PM   #9
I didn't really believe it myself until I tried it.
But that is beside the point. I want to build a stand alone 1KHz sine wave generator powered from 3V
Old 18th November 2011, 06:09 PM   #10
I don't see big problems -80 dB spurs are pretty good compared to what a "simple" analog sine oscillator will do
no way you're going to get the narrow linewidth even a poor xtal in a cheap DAP will give
I created a 1 kHz sine in Ltspice - exported with the .wave function
used foobar2000, lame 3.99.2, encoded as mp3 v2,
reconconverted to .wav - back in to Ltspice
below is a 1048576 point fft of 10 seconds 1kHz sine > 16/44.1 .wav > mp3 v2 > .wav
Schematics needed for 3V 1KHz Sine wave generatorHide this!Advertise here!
Need -60dB 1kHz sine wave for CD Bernhard Digital Source 30 26th March 2012 11:31 PM
Sine Wave Generator with bulbs (Sine-lightenment) Rodeodave Everything Else 6 21st July 2008 12:19 PM
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 12:15 AM
