Op Amp Rail Splitter Question
Old 19th March 2013, 02:43 PM   #21
jcx is offline jcx  United States
1988? - IBM PC at work, had been running free Spice for years by then - no schematic entry - had to enter netlist text file - sure beat punch card "decks"
Old 20th March 2013, 06:10 AM   #22
RNMarsh is online now RNMarsh  United States
RNMarsh's Avatar
I remember doing that -- decided to wait until it got better and more integration then tried a few and settled on Microcap ever since it became available.
-RNM
Old 20th March 2013, 05:44 PM   #23
Mark Johnson is offline Mark Johnson  United States
For me, 1978. SPICE ran on the company mainframe in a glass-walled, raised floor, air conditioned, limited access room. We ran SPICE2 version D (pre 2G6!), and yes it ran from decks of punched cards. Fortunately there was an '026 keypunch that engineers (rather than trained keypunch operators) were allowed to use. Hand your deck to the SysOp, make sure your JCL included a comment with your phone extension number! Come back 2-3 hours later for the results: a 2-inch-thick stack of fanfold printer paper. Then whip out your colored pencils and connect the dots.
At the time, DRC still was done with plots, rulers, eyeballs, adhesive dots, and summer interns.
Old 20th March 2013, 07:30 PM   #24
RNMarsh's Avatar
The good old days werent always so great.
-RNM
Old 21st March 2013, 12:32 PM   #25
magnoman is offline magnoman  United States
Even today I get this funny feeling when I view a netlist.
Actually didn't like schematic entry when it first came around.
Velum schematics with reference designators blank until the last minute.
My employer still requires schematics with "not used" and "last used" only a few of us remember the actual need.
Problem today is you cant blame a bent corner.
Thanks for the memory lane
-Antonio
Old 6th July 2015, 01:45 PM   #26
jackinnj is offline jackinnj  United States
jackinnj's Avatar
You could use one of the TI high voltage opamps, not just the '604:
Old 6th July 2015, 02:30 PM   #27
Since the opamp output bias point is halfway between the rails, you don't need or want a Rail-To-Rail-IO opamp. Since you don't need to swing the opamp output very far at all, you can run the opamp using lower voltage supply rails, created via a pair of zener diodes or a pair of LM7812 3-terminal regulator ICs. With less voltage between the opamp supply rails, you can use those zippy 350 MHz opamps like the LM7171, that don't go up to nosebleed supply voltages.
And since you're not swinging the opamp output very far at all, you can use monolithic Darlingtons for the emitter followers, without compromising output swing. If you wish. My railsplitter pcb uses TIP142/TIP147.
Me, I'd prefer series resistors in the emitter legs, plus a bias splitter ("VBE multiplier"), just to set up a known amount of standing bias current in the output stage.
Op Amp Rail Splitter QuestionHide this!Advertise here!
Virtual ground / Rail Splitter using only LM317 JediRemi Power Supplies 4 6th April 2011 03:52 PM
Wanted: Op-amp with single supply, 32V or more, and rail-rail capability akis Power Supplies 3 13th November 2010 01:53 PM
cmoy sijosae rail splitter cachupito Headphone Systems 10 20th May 2010 03:42 PM
simple HV rail splitter/floating ground - would this work? Rodeodave Power Supplies 3 20th July 2008 04:12 PM
amplifier and rail-splitter forming a filter? Dominique Solid State 12 2nd May 2006 06:26 AM
