Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th October 2011, 11:08 AM   #1
jonstanza's Avatar
Default prototype preamplifier
Dear sirs
I put a topic here, something I had in mind for some time already, but for professional reasons, was always limited by the lack of time.
The question is a personal project, which personal and professional knowledge I decided to build an active preamp (solid state) that has lasted eight years your development
With the help of software Auto-CAD in conjunction with our imagination is possible to create a housing with a personal designer.
The housing material is aluminum. Has two RCA inputs and two input xlr. Has one RCA output and one xlr. The front panel has an input selector and one attenuator. On the right side is the standby button.
The pot attenuator is an ALPS modified. Inside, Teflon is used to dampen the vibrations of the box..
The supporting foot are stainless steel. 3 foot is used at strategic points to reduce the resonance.
I enclose photos. then inform details of the preamp circuit and power supply
note: my English is somewhat bad, there may be some errors. I'm sorry.
jon
Old 13th October 2011, 11:22 AM   #2
jonstanza's Avatar
the pieces were made on my specifications in company specializing in aerospace.
Old 13th October 2011, 12:16 PM   #3
Junie is offline Junie  Philippines
Junie's Avatar
that's a serious DIY in there Jon, a very detailed construction and well planned project huh. Well done and good luck with your build mate.
Old 13th October 2011, 03:00 PM   #4
gk7 is offline gk7  Europe
Looks fantastic. But itīs rather expensive, I believe, no ?
Georg
Old 13th October 2011, 04:08 PM   #5
jonstanza's Avatar
thanks junie
Old 13th October 2011, 04:29 PM   #6
Mention of aerospace and it must be more than rather expensive!
Or someone repaying a big favour. Friends help sometimes.
Between 30 and 46years ago I got three little jobs done in Ferranti.
I await further details, both pics and description/specification
regards Andrew T.
Old 13th October 2011, 04:33 PM   #7
jonstanza's Avatar
yes it is a "little" expensive
best regards
jon
Old 13th October 2011, 04:41 PM   #8
jonstanza's Avatar
pcb layout
The software used for the design of the board is the Altium Designer... excellent, sophisticated and with a margin of error "null". The best that has passed through my hands.
Link:
http://products.live.altium.com/#r10/explore/bd-PcbLevelDesign
regards
jon
File Type: jpg designer boardīs with altium designer.JPG (315.7 KB, 161 views)
File Type: jpg designer pcb with altium software .JPG (305.3 KB, 145 views)
Old 13th October 2011, 04:51 PM   #9
ide2003 is offline ide2003  Indonesia
very nice Jon, I admit this is the first time I see a roller bearing used in the amp ..and I have made many custom amp chassis...
best, TeguhPS
Old 13th October 2011, 04:59 PM   #10
jonstanza's Avatar
Power supply
Consists of two bus (positive) and (negative). Each bus has four diodes ultrafast, 15 A, 35 ns (MUR1520) of ON Semiconductor, the capacitor are the from Nichicon KG (Gold Tune), totaling in all 47200 uf . (four 6800UF and two 10000uF).
The regulation this based on JFET (PN4393) Fairchild, (do not use 2sk170 because of counterfeits) and also I had better response with this model.
In series with the JFET this a zener (1N5250). From this point of reference there is an amp that goes to the output transistors of the power supply. (ECX08N16-Z) positive rail and (ECX08P16-Z) negative rail.
To prevent vibration the transformer is suspended on shock absorbers to neoprene
There is also a small circuit in the power supply that is responsible for the mute / standby. In reality the whole circuit is designed to be connected to the current 24 hours per day.
regards
jon
AMP7 prototype peranders Class D 9 25th April 2009 05:41 AM
my new prototype zilog Power Supplies 5 25th September 2008 05:03 PM
Prototype and risk stef1777 Parts 5 1st May 2007 04:03 PM
New Gainclone Prototype mdlover Chip Amps 19 25th June 2003 02:00 PM
Page generated in 0.12043 seconds (83.66% PHP - 16.34% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
