| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#31 |
hello hags!
my choice to not choose the 2sk170, I had many problems with it, changed its features with temperature, had to buy 20 units to have two identical (I use a differential input), was a sweet sound and slow. And many counterfeit units. The 2N5566 is very stable with temperature, the sound is very natural, low noise ... the best we've tested to date. amazing, no comparison to 2sk170. best regards |
#32 |
hello BowtoEd
my choice to increase the capacity of power transformer, was to have greatly improved the low frequencies in audio and .... thanks for your opinion regards jon |
#33 |
I'm now developing unit riaa (phono stage), if possible I'll put here a topic about my new project.
Here is some pictures of that unit. -riaa passive correction, with capacitor dynamicap, -mother board, supply rails with a copper OFC 6N. -power suplly identical to the preamplifier -and one module of amplification right or left. note: the boards do not have all the components and after all the components are placed. is cleaned resin of solder. best regards |
#34 | |
In a differential input they sound a little slow and I'll also add somewhat rolled off. This has been well documented by Borbely. You can cascode the input but at a higher parts count and more matching. The Linear Systems LSK170s are a step up but a real, current production alternative doesn't exist. I've searched high and low for a few 2N5566 that you used but unless I want over 100pc @~$200USD there are none available.
"Some lures are designed to catch fish, others are designed to catch fisherman." |
#35 |
if you need 2n5566, I recommend utsource. Send an email to Mr.. Davis. sales@utsource.net The price ranges between 8 to $ 10
best regards jon |
#36 | |
If my preamp had bass problems my first instinct wouldn't be increasing the PT capacity. I'd look at each amplifier and probably change out coupling or bypass capacitors. If there were an NFB loop then I would redesign it. If none of that worked I'd get bigger power supply capacitors. I'm not criticizing you for your PT choice. Your amp, your parts, your decisions. What method did you use to find the right PT? Was it just trial-and-error or did you calculate it by using the inductance of the pri/sec? Ed |
#37 |
Hi John,
Excellent project Congratulations and best wishes. |
#38 |
Wow John, Two Thumbs up for your project. Truly combination of art and engineering!
| AMP7 prototype | peranders | Class D | 9 | 25th April 2009 05:41 AM |
| my new prototype | zilog | Power Supplies | 5 | 25th September 2008 05:03 PM |
| Prototype and risk | stef1777 | Parts | 5 | 1st May 2007 04:03 PM |
| New Gainclone Prototype | mdlover | Chip Amps | 19 | 25th June 2003 02:00 PM |
