| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Did a little tinkering with a calculator and came up with this schematic based on it.. Based on the calculator it should work, Thoughts?
This should provide a variable selection of 55-110Hz if it works right. The pot is a 10k Dual Linear. Reference: Pronine Electronics Design - Sallen-Key Active Low Pass Filter Calculator I have a MC1458P dual OP-Amp laying around that I could use. Do you think that would be an OK part to use? Last question.. Does anyone have a reference to a simple way to mix L and R channels for a mono subwoofer application and still keep them isolated? Thanks!! |
#2 |
That will work. Here's the answer to your second question. The first stage is an inverting summing amp, the second stage "uninverts" the signal.
SUMMING AMP.JPG Mike |
#3 |
At first I thought maybe you were referring to a dynamically variable filter (which would change the xo f with changing loudness), as that would be really useful (and new?)
#4 | |
I just tinker and usually get lucky with something that works well enough ![]() As for the summing amp, I can see how it would combine the signals but will any of the sound from say the left just go through both resistors and back out the right? The signal going into the combiner/mixer also connects to a stereo amplifier to do everything above 80Hz or so. Maybe so little would get back that it wouldn't be noticeable, but thats why I'm asking.
#5 |
No, there is no feed-through from one output back to the other. Due to the way opamp feedback works and because the non-inverting input is grounded, the junction where the input resistors and the feedback resistor meet at the inverting input is a virtual ground. Therefore anything connected to one input is totally isolated from anything connected to the other input.
Mike |
#6 |
Nice, thanks for the info
![]() I was thinking of using the OPA 4134 then I could use the same IC for both XO and Mixer. Might save a little money and make the design tighter. |
#7 |
That would be a good choice for this application. You can eliminate one of the opamps by not using the second stage inverting amplifier and simply connecting the sub-woofer to the amp with the terminals reversed, that will "un-invert" the signal and achieve the same thing. You might want to post your final design here before you build it to make sure it's alright.
Mike Last edited by Michael Bean; 25th September 2011 at 11:25 PM. |
#8 |
My basic plan was to use that mixing circuit, into the crossover circuit then into a single Peter Daniels LM4780 kit running in parallel mode to drive a 4 ohm subwoofer.
I have a couple 6.2uF capacitors that I was planning to use on the inputs in front of a dual 10k log pot for a volume control. An additional idea was to add a couple switches so that I could bypass the mixer and crossover and run it straight as a regular stereo amp. |
#9 |
The volume pot should be put between the filter output and the LM4780 amp input, that way you will get the best possible signal to noise ratio.
Mike |
#10 |
That makes sense.. have a few components to get before I can put this together and try it.. Thanks again!!
| DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM | stevep314 | Analog Line Level | 0 | 10th August 2010 09:15 PM |
| Ultimate Active Low Pass Filter | toshiba_nz | Analog Line Level | 0 | 26th May 2010 07:25 AM |
| Variable High pass filter? | ayearofholidays | Instruments and Amps | 1 | 30th April 2009 01:53 AM |
| Variable Low pass for sub | ThSpeakerDude88 | Chip Amps | 3 | 1st September 2006 11:55 PM |
| Variable frequency low pass filter | pk386 | Chip Amps | 11 | 25th September 2004 01:43 PM |
| Page generated in 0.12257 seconds (77.54% PHP - 22.46% MySQL) with 11 queries |
