I ran an rca out from my computer soundcard, to an active crossover, and out of the 1/4 jack of that to the 1/4 jack of my amplifier.
Is your crossover a "RANE" ?
Yes 2 is hot 1&3 is ground (see link). You may encounter hum, but I’ve done this many a time, typical CD to “commercial amp” and works okay. I had better sound with a balanced to unbalanced converter.
How to wire an XLR
How to wire an XLR
This means you have to add a jumper from pin 1 to pin 3 on the xlr jacks to use the TRS plugs. A piece of bent thick copper wire can be used, or you can purchase little plug cap things that do the same job.
Doing this with copper speakerwire bridging them WORKED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
YAHOOO!!!!
Unbalanced untill I can attain the balanced converters! Thanks for all the help and insight everyone! I would have gotten nowhere without you all! I learned a lot!
Congratulations on the OP getting it to work. BTW, you forgot the !!!11!!111!!leventy!!1!!!!111111!I'm pretty sure Rane has a technical note on their website about connecting balanced and unbalanced. If you have (or can download) the manual for the amp, it should have a page explaining how to connect unbalanced sources.
Or, with one quad op-amp you can make a stereo balanced line driver. Wire 2 sections as inverting buffers, two as non-inverting.
For future reference, the Rane technical note would be this:
Sound System Interconnection
I use the Henry Engineering Matchbox for my balanced equipment needs. Check their website for older unit manuals, they even have schematics if you want to DIY a matchbox for yourself.
Watch out for single supply converters such as the SAMSON S-Converter. I originally used them and did not like the rough sound and low headroom. Got some Henry units and along with a dual 15 volt supply they even have op-amp sockets to do some op-amp rolling. OPA op-amps sound good in this application.
I snagged one of my Henry units on ebay for 5 bucks as the seller had no idea how these things work, bargains are out there.
Unfortunately the M*M Unbal didn’t do well. I had one on the shelf stashed away in case I needed one and finally got it out. It worked fine for about a week (couple hours a day) – then poof – right side stopped working. I called about a replacement but it was a few weeks over the warranty period.
Always amazed a how company will risk a poor reputation over a few bucks.
oiphy I moved your post to the pass labs forum http://www.diyaudio.com/forums/pass-labs/200554-help-needed-balanced-unbalanced-input.html
Andrew I deleted yours as no longer necessary
- Analog Line Level
- Extremely Frustrated!!! Why won't my amp get loud!?!?!
