Go Back   Home > Forums > Source & Line > Analog Line Level
Old 9th September 2011, 08:49 PM   #1
bizbad is offline bizbad  United States
Question Pre-Amp earthing concern
I am building a pre-amp with an external wall transformer. It is a 16v ac transformer without the third terminal for earth ground. I have seen others with this configuration but never wondered about earthing. Is earthing necessary on the pre-amp and if so, how is it done?
Old 9th September 2011, 10:02 PM   #2
sofaspud's Avatar
No, you don't need an earth ground.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 10th September 2011, 10:50 AM   #3
If the wall mounted power supply is rated "double insulated" and carries the two concentric squares symbol, then anything downstream that is powered by that ClassII supply is safe to use without additional PE to case earthing.
However, if that pre-amp has exposed conductive parts and it is connected to some other apparatus that does not meet the ClassII standard, then there remains a risk of electric shock if the other apparatus goes catastophically faulty.
regards Andrew T.
Old 11th September 2011, 02:38 PM   #4
Thanks, I am good to go then.
Earthing concern - pre amp and traffo help AndrewGM Solid State 19 9th January 2010 11:56 PM
earthing advice on a US amp woodturner-fran Tubes / Valves 7 16th January 2009 12:25 AM
Cause for concern -- scorch mark in tube dsavitsk Tubes / Valves 3 17th April 2007 04:23 AM
A Grounding Concern Code Parts 4 26th January 2007 10:26 AM
Thermal management: it this not really of concern? LowRedMoon Tubes / Valves 18 16th November 2006 01:11 AM
Page generated in 0.07681 seconds (67.53% PHP - 32.47% MySQL) with 10 queries
