Dual I/V stage implementation for Buffalo II & III
Closed Thread
Old 6th September 2011, 03:43 PM   #1
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Default Dual I/V stage implementation for Buffalo II & III
I would like to start this thread to see if some of you would be interested in having a switchable dual I/V stage for the Buffalo II and III. Those are the DAC designed by TwistedPear Audio.
My thoughts on this is that some people love solid state I/V and some love Tube I/V. If you're like me, depending on the kind of music you're listening you might like one or the other.
What I'd like to propose is some sort of way to have both a Legato/IVY I/V stages from TPA and a third party I/V that could be selected with the press of a button or switch.
Now, I'm currently running a Dual Mono Buffalo II setup with Dual Legato 3.1 and I also have a tube I/V from DVBProjekt (Tube-I-Zator).
I was planning to have a switch board sandwiched between the Legato/IVY and the Buffalo II/III that would do the switching using latching relays. Latching relays to not induce EMI in the signal. And having this board sandwiched in between would allow for shortest traces as possible.
I hope this will bring some great ideas and a possible design. Since I'm no circuit designer, I would like to know if someone with experience would gladly provide help in designing the circuit. If not, I have a good source (a friend) that could do it but timing for him is not good at the moment.
Here's a drawing of what I was thinking
https://picasaweb.google.com/lh/phot...eat=directlink
There would also be a controller on a different board that would carry the electrical and electronics to switch the relays. I do not want to have any electricity flowing on the I/V circuit aside the balanced audio signals, hence the use of latching relays.
Of course we would need the right measurement of the PCB holes and connectors of both Legato/IVY and the BII/BIII to align things. I have sent a PM to Russ White and asked him for the Gerber files but only containing the holes and connectors alignments. I'm relying on their good heart for this help!
I was thinking of a group buy if enough people are interested!
Let's get this started!
Do
Old 7th September 2011, 01:24 PM   #2
pinnocchio's Avatar
As I would really like to have this started, I will be offering 100$ donation to the DiyAudio forum if someone will be interested in designing the board for me (for all of us).
I will provide the needed information and would love people to participate and share their ideas
Would also like to know who would be interested in such a board.
Old 7th September 2011, 04:39 PM   #3
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Hi Do,
as far as i see it on the attached wiring diagram, you need 6 lines per channel to do what you want to, correct?
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 7th September 2011, 07:08 PM   #4
pinnocchio's Avatar
Hey Oliver!
I need 6 lanes per DAC (we have two BII/BIII) to connect the BII to the Legato/IVY and another 6 lanes per DAC to go to the third party I/V . In dual mono, please see diagram.
When they're installed, they stack perfectly on top of each others and the pins are aligned making a point to point connection. We'll need at least 4 latching relays, one for each "left and right" of each BII/BIII.
See diagram of what has to happen when using an external I/V in dual mono mode
I'd like to have the relays as close as possible to the BII and legato as possible.
Please let me know if you have any questions
Do
Old 7th September 2011, 07:21 PM   #5
qusp is offline qusp  Australia
qusp's Avatar
even a few cm and a fraction of an ohm will effect the resolution and dnr of the current output of the bII in a meaningful way, i dont think this is a great idea tbh. you should if you can avoid it and must push forward, try to avoid switching the return lines
Old 7th September 2011, 07:47 PM   #6
pinnocchio's Avatar
I have currently installed a Tube I/V and the setup is not final. I'm using all silver cabling.
Sure it can change the current output but trust me, I have good ears and it sounds amazing. The goal is to make the traces really short. We're all about experimenting.
I do however understand your concern.
Old 7th September 2011, 07:50 PM   #7
pinnocchio's Avatar
Here's a quick hand drawn diagram for only one of the two BII DAC in the dual mono setup.
I can put this on a better format if needed but it is the idea...
Old 8th September 2011, 10:43 AM   #8
qusp's Avatar
good ears, silver cabling or not, using subpar methods to connect the IV stage like using relays, will singlehandedly remove any advantage gained by having a dual mono dac in the first place
Old 8th September 2011, 11:51 AM   #9
pinnocchio's Avatar
Hi Qusp,
I do appreciate the feedback but if you could also provide some positive feedback, maybe tell us how you would do it instead of just pointing out the bad.
If using relays is not good then there must be tons of people wasting their times building / implementing R2R volume control using relays...
After all, this way of thinking would have never brought us to the moon!
Please don't be a show stopper and see the positive side of anyone interested to use an I/V stage of their liking. I do love the Legato / IVY stages but there's plenty of people that won't give up their tube I/V for SS output...
Lets just be innovative and find ways around this issue.
Thanks for your understanding
Old 10th September 2011, 09:38 PM   #10
pinnocchio's Avatar
Well, I have completed my dual mono BII with Tube-I-Zator tube output and it sounds incredible!
I will post picture later on.
I'm still looking for some good talent to create that board... I could split the bounty half and half... Half to DiyAudio and half to the person creating it... Or let me know what would motivate you!
Closed Thread
Dual I/V stage implementation for Buffalo II & IIIHide this!Advertise here!
Buffalo II & transformers markusA Twisted Pear 629 27th November 2016 01:38 AM
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
FS:Buffalo DAC II with tube output stage Forane12 Swap Meet 2 12th February 2011 06:08 PM
FS: Buffalo II DAC + Placid Combo, Legato I/V Stage, 2x Placid BP Modules damohpi Swap Meet 4 23rd November 2010 08:51 AM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
