Best Pre amp Kit on the market
Old 5th September 2011, 04:29 PM   #11
TerryO is offline TerryO  United States
TerryO's Avatar
Originally Posted by domtweaker View Post
I thought K&K would be a better choice ?
It seems that you've already have found what you want. I'm sure the K&K is a fine product, so I look forward to seeing your progress.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 5th September 2011, 04:39 PM   #12
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
B1 Buffer Preamp
for a tube pre 'kit', I would choose Broskie
but I don't understand why a tube crossover needs additional gain preamp ?
wouldn't a buffer do ?
Old 5th September 2011, 04:44 PM   #13
hags is offline hags  United States
A better choice for what?
There are many good preamp kits available, even more DIY, Pass, Borbely, Aikido all come to mind.
Pick your flavor.
"Some lures are designed to catch fish, others are designed to catch fisherman."
Old 7th September 2011, 09:37 PM   #14
Brett is offline Brett
Brett's Avatar
0: [Root question] Why do you need a preamp at all if you are going directly into the active xover? Source selection and VC can be done here without any other active components.
1: Does it need gain? If so, how much? Edit: saw 6dB. Can you not get that in the xover?
2: Does it need to be tube?
3: If tube, does it need to be a kit? Or can you put something together P-P?
Old 8th September 2011, 05:38 AM   #15
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
I totally agree with Hags for the Borbely All FET Super Buffer stereo PCB
If you want good "kits" you can try those on BottleHead web site, there pretty good!
Foreplay III Line Stage Kit
and I would consider getting the upgrade package that has shunt regulators and more...
You can also try this one. Many modified it with led volume
Transcendent Sound Grounded Grid Preamp
Those two kits are well renowed and sound good!
Have fun!
Do
Old 9th September 2011, 12:04 PM   #16
dheming is offline dheming  United States
dheming's Avatar
As another option for you to consider, Decware offers a compact class A single-ended-triode tube gain stage kit: ZKIT4
Old 9th September 2011, 01:07 PM   #17
merlin el mago is offline merlin el mago
merlin el mago's Avatar
thanks hags but I want to get something better than that
Old 10th October 2011, 06:28 PM   #18
erikb1971 is offline erikb1971  Netherlands
got to love this guy! Thank you for all your reactions!
Old 10th October 2011, 08:19 PM   #19
TerryO's Avatar
I'm just wondering why the OP even posted.
Evidently, what would be considered good, or even great, by the "peasants" on this forum, doesn't meet his exalted expectations.
Let's see:
Boberly
Broskie
Bottlehead
Grounded Grid
Decware
All of the above aren't up to the unstated standards of our OP.
However, he feels that the K&K unit meets his (unstated) criteria and unwavering standards of excellence.
I believe that it's totally unproductive to pursue this any further.
Goodbye Dom...
Old 10th October 2011, 09:25 PM   #20
Let's see:
Boberly
Broskie
Bottlehead
Grounded Grid
Decware
Goodbye Dom...
Alot of the time people ask questions not for the correct answer or difference of opinion but for reinforcement and affirmation of their answer/opinion.
Certainly we've all been guilty of this.
Best Pre amp Kit on the marketHide this!Advertise here!
DIY pre-amp kit vote cryo Tubes / Valves 30 4th May 2011 05:47 AM
Bit of a kit market research. R-Carpenter Multi-Way 9 4th November 2007 01:32 PM
help with layout of multi-kit chip-amp pre-amp okapi Chip Amps 8 12th January 2007 12:03 AM
RCA Jack/Plug Selection/Switches Pre-amp & 3875 Premium kit Destroyer OS Chip Amps 15 22nd August 2006 07:43 PM
New pre-amp kit just arrived in mail elizard Solid State 72 7th April 2003 05:11 PM
