Best Pre amp Kit on the market - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 10th October 2011, 08:47 PM   #21
Originally Posted by hags View Post
Certainly we've all been guilty of this.
But I think it is polite to thank people for confirming you are right :-)
Old 10th October 2011, 08:52 PM   #22
hags is offline hags  United States
Sure, if in agreement, which from the sound of it, the OP was not.
I'm not sure how my comments came off but I'm in full agreement with TerryO. Suggestions have been given and they're not being well received. Why ask for opinions if you're going to pooh pooh all that are given?
"Some lures are designed to catch fish, others are designed to catch fisherman."
Old 10th October 2011, 08:54 PM   #23
oh well... Canadian :-)
Old 10th October 2011, 11:46 PM   #24
pinnocchio's Avatar
Hey I'm Canadian too...
I think he's just a confused one...
But I'm totally in agreement with you guys... We wasted time on this... Especially when I see what we had suggested which was really good!
Do
Old 11th October 2011, 01:55 AM   #25
linuxworks's Avatar
ob disc: I was one half of the design team for this
the AMB alpha 10:
very quiet (discrete buffers and discrete PSU) and 127db in half db steps via latched relay atten. open source arduino code for the lcduino controller side of things. 8 selectable ports (each can be set for in/out/disabled). IR remote control and motor pot for UI elements.
again, I worked on this so I'm biased (lol) but its fully high-end by design and by spec. a lot of build time (many connectors and large motherboard) but that's what diy is about - lots of time on your hands
my version does not look as good; the photo show's amb's actual version.
My Photostream:http://www.flickr.com/photos/linux-works/
Old 11th October 2011, 02:16 AM   #26
frugal-phile(tm)
planet10's Avatar
Best preamp, money not an object... the Vacuum State RTP certainly has to be a contender. The Marchand between it and everything else will not allow you to appreciate it thou.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th October 2011, 02:19 AM   #27
the AMB alpha 10:
I've built the a20 boards for this and it is currently in use. Very simple, very nice sounding the only thing they could've done to top it is to add a dc servo. The tempo drift on the jfets is a PITA not to mention the thought of amplified DC.
Cascoding the input jfets would've been nice as well but I'm nit picking.
Old 12th October 2011, 02:34 PM   #28
For what it's worth:
I put together a Pass B1 buffer using a Goldpoint stepped attenuator that still cost less than $200- .
I have directly A/B'd it with my friend's Audio Research SP15 and can say (gain limitation noted) that the advantage goes to the B1. Both sound fantastic but the B1 has more distinct imagery.
Old 19th September 2013, 06:34 PM   #29
dave
It is not a kit though is it? It doesn't appear to be.
Old 19th September 2013, 06:37 PM   #30
frugal-phile(tm)
planet10's Avatar
Certainly at one point one could get sn RTP kit (mine was a kit). You will need to check with Vacuum State.
dave
DIY pre-amp kit vote cryo Tubes / Valves 30 4th May 2011 04:47 AM
Bit of a kit market research. R-Carpenter Multi-Way 9 4th November 2007 12:32 PM
help with layout of multi-kit chip-amp pre-amp okapi Chip Amps 8 11th January 2007 11:03 PM
RCA Jack/Plug Selection/Switches Pre-amp & 3875 Premium kit Destroyer OS Chip Amps 15 22nd August 2006 06:43 PM
New pre-amp kit just arrived in mail elizard Solid State 72 7th April 2003 04:11 PM
Copyright 1999-2017 diyAudio
