| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
For example, I’m using typical Y splitter from the mono subwoofer “out” to drive to two amplifiers. Not have any problems that I can tell, plenty of gain, etc. However thinking about add a third amplifier. How many times can you split a line level output? I didn’t really want to add a powered splitter; I thought it might create more problems – than it would help. If I need to add a powered device, what’s a good unit? My apologies if this topic has been posted before. |
#2 |
For a sub-out adding another amplifier should be fine. Driving cable capacitances at high frequencies causes the normal passive limit. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#3 |
There's also the impedance question. As parallel more inputs, the total impedance seen by the source drops. This requires more current and, eventually, the source begins to distort the signal. Unfortunately, there's no one-answer-fits-all solution here because input impedance of "line-level" inputs can vary quite a bit.
| Kenwood P-T400 - line level output ? | jives11 | Analogue Source | 1 | 2nd October 2008 03:50 PM |
| iPod's line level output? | Dxvideo | Chip Amps | 9 | 26th May 2007 02:41 PM |
| Headphones output to line level | Simpleton | Parts | 1 | 13th May 2007 09:54 PM |
| Can I split line level input? | dublin78 | Chip Amps | 15 | 14th February 2007 03:43 PM |
| Preamp with line level output | linuxenthusiast | Analog Line Level | 5 | 30th July 2006 11:42 AM |
| Page generated in 0.06954 seconds (70.00% PHP - 30.00% MySQL) with 10 queries |
