Go Back   Home > Forums > Source & Line > Analog Line Level
Old 29th August 2011, 11:15 AM   #1
Lightbulb frequency control of higher order filter with mono pot
I would need a (low phase shift) 12 dB high-pass filter, where I can change the cut-off frequency just with a mono pot.
Is this possible, since a 12 dB filter is a 2-pole (when using caps and resistors) and the cut-off frequency of each pole has to be changed simultaneously and so I would need a stereo pot.
Any experiences?
Old 29th August 2011, 01:59 PM   #2
THAT app not 130 describes a VCA controlled state-variable filter. Not quite what you want but maybe a guide. E
Old 29th August 2011, 02:16 PM   #3
jcx is online now jcx  United States
its got one knob...
Old 29th August 2011, 03:28 PM   #4
Thanks for your posts.
The mechanical solution would be probably too "expansive"
VCA solution should work. Is this standard solution filter freq by a pot? I can't remember haven't seen VCAs in synthesizer filters ...
Old 2nd September 2011, 01:38 PM   #5
If you impolement your filter as state-variable filter you might control it using CMOS analog switches and a pulse-width modulator.
Charles
low pass filter and volume control pot suresh Solid State 1 29th April 2010 04:05 AM
WWYD? Higher order acoustic slopes and lower order targets cuibono Multi-Way 3 3rd December 2009 11:36 PM
Wave transformation, Higher order modes? thadman Multi-Way 2 5th November 2009 11:53 AM
My 1st order butterworth filter better than 4th order L-R: Why? philipreji Solid State 61 1st March 2007 04:50 PM
Higher order crossovers is it possible with LM4780? diysmartdeep21 Chip Amps 0 10th February 2005 12:17 PM
Page generated in 0.08548 seconds (73.32% PHP - 26.68% MySQL) with 11 queries
