Using digital interconnect as analog interconnect
Old 24th August 2011, 05:21 PM   #11
DF96 is offline DF96  England
Termination resistors? For the coax impedance at 100Hz, 1kHz or 10kHz - all different. Coax at audio frequencies does not behave quite like coax at RF, so you can't terminate it in the same way.
Coax cable should not sound either bad or good, it should not sound at all. Exception is if you have a very long length - 100's of metres, or drive it badly from a high impedance.
Old 24th August 2011, 05:33 PM   #12
Pano is offline Pano  United States
Pano's Avatar
I agree.
Old 24th August 2011, 06:35 PM   #13
new2hifi is offline new2hifi  United States
Thank you all for so many responses.
I actually had that cable in hand for digital use. I just wanted to experiment thus I took out the RCAs and installed BNC bulkheads on pre/amp. I didn't hear any difference, must be my non-golden ears. I did like the secure connection offered by BNC and solidity of Belden.
Other day I was on audiophile cable manufacturers' websites and saw space age designs for single-ended signal. Thus now, I am seeking technical difference of using coaxial or twisted pair for analog signal.
Old 24th August 2011, 06:37 PM   #14
Originally Posted by AndrewT View Post
Twisted Pair or Twisted StarQuad, with or without shield.
AndrewT, Canare sell such cables in foil and braid shields which are mutually exclusive. Which shield will work better in interconnects application?
Old 24th August 2011, 07:00 PM   #15
Unless you have long interconnects, or lots of local interference, the cable type does not really matter. Connector quality and grounding can be more important. You can safely ignore much of what is said on many cable vendor websites.
Old 25th August 2011, 03:30 PM   #16
marce is offline marce  United Kingdom
Some interesting notes on audio shielding.
http://www.compliance-club.com/archi...ive/021122.htm
http://www.compliance-club.com/archi...ive/020918.htm
Regarding co-ax, I am curious as to what mechanism causes these type of cables to not sound as good as other topographies.
Old 25th August 2011, 05:55 PM   #17
Could that be because the Signal Return is not shielded?
The Signal Flow is shielded.
The difference in voltage between the Signal Flow and the Signal Return at the Receiver input is amplified to be sent on to the next stage.
If the Signal Return is subject to interference such that that voltage difference signal is adversely affected then the amplifier is being fed with a "bad" signal and cannot send on a "good" copy to the next stage.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 25th August 2011, 06:28 PM   #18
A magnetic field would affect inner and screen together, so apart from hum loops is not an issue. An electric field would only affect the screen, but that is grounded so the effect is to inject a small ground current. This could be a problem if the input grounding cannot handle it, but a screened twisted pair would have the same problem.
Old 25th August 2011, 06:47 PM   #19
Originally Posted by DF96 View Post
............. a screened twisted pair would have the same problem.
I am not sure that is the case.
The twisted pair is immune to the external field due to the screening and due to the close coupled twisted nature of the Flow and Return.
Ground current could be directed along the screen if needed or it can be single end connected as screen only.
The amplifier sees the voltage difference at the receive end of the Flow and Return pair.
I don't think that can be said for a Coax, which must have the screen connected at both ends.
regards Andrew T.
Old 25th August 2011, 08:10 PM   #20
Assuming no hum loops, the receiving end sees the difference between signal and return for both cases. The twisted pair is still subject to magnetic fields, and relies on cancellation - the screen is likely to be too thin to stop an audio frequency magnetic field. The twisted pair relies on twisting, the coax relies on cylindrical symmetry. There is a small advantage to the twisted pair if the screen is poor - you can still get cancellation if you have a differential input, even if an external electric field induces a signal. This may mean that a cheap twisted pair is better than a cheap coax.
Using digital interconnect as analog interconnectHide this!Advertise here!
Digital SPDIF-AES/EBU interconnect Nuuk Digital Source 3 11th April 2012 07:22 PM
Silver interconnect tubee Parts 0 13th January 2009 08:25 PM
JAV 0.8m interconnect and digital for Sale jayaudiovisual Swap Meet 0 7th August 2006 11:12 AM
Silverblue Interconnect dynoPort Everything Else 0 19th October 2004 08:00 AM
Interconnect termination hbarki Parts 0 10th April 2004 01:51 PM
Copyright ©1999-2017 diyAudio
