| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
I'm interested in using the unused telephone hookups in my small apartment to send line level inputs to different rooms. My understanding is that theres 2 wires for power and 2 wires for signal. If there's no service going to the line, couldn't I feed low level audio through the signal lines to seperate amplifiers in different rooms?
Thanks for any feedback |
#2 |
There are 2 wires (red/green) or 4 wires (+black/yellow). Power and signal share a pair so there may well be just 2 wires. The most important thing is to be absolutely 100% certain nothing remains connected to the telephone network. Then you could use this for distribution, but how effective the end result I could only guess. Using a line driver is probably a good idea.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#3 |
No. The two wire incoming line provides power and AC connections. In the UK : UK Telephone Wiring Your main issue would be lack of shielding, hum, followed by some noise. You don't even have twisted pairs to help, like the incoming pair line. I'm not saying it can't be done, but I've never done it, don't think it will work. But between two extension points not linked to a master socket you could try connecting the 4 wires as L-, L+, R+, R-, it just might work, or then not. I think it won't work well, but that does depend on low driving impedances. (i.e. it would be easier to use them for extension speakers than line level.) rgds, sreten. (ex telecoms amongst other things) You would need to disconnect the wires from the master to the first extension ....
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 18th August 2011 at 10:44 PM. |
#4 |
#5 | |
I learned this a couple of months ago when running new phone wiring in a house- it was a surprise to me. |
#6 | |
That is not surprising as the twisted pairs are still fine for telephony, but the wiring is much more suitable for computer LAN's and the like. Though wireless hubs are taking that over. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#7 |
I live in the US and my understanding was that there was a low voltage DC (+/-) and then a input and output. If none of these are in use and the run is less than 30', I don't think that these concerns are substantial. I'm going to give it a try sometime this week and post back
Thanks |
#9 |
Or into yourself! I got zapped once by that.
#10 | |
| Headphone amp with mixed-in telephone audio | krfjr1965 | Solid State | 3 | 10th March 2010 03:50 PM |
| Need connection diagram for Planet Audio HVT754 | patife | Car Audio | 2 | 20th April 2007 11:43 AM |
| Single connection USB Audio PLUS RS232 Conversion? | mbcouple | Digital Source | 1 | 16th January 2007 01:06 PM |
| Audio Alchemy I2S connection? | quantran | Digital Source | 4 | 3rd October 2004 12:46 AM |
| Scope connection on Audio Dummy load | Tarzan | Equipment & Tools | 9 | 27th August 2004 07:34 PM |
| Page generated in 0.09468 seconds (86.72% PHP - 13.28% MySQL) with 10 queries |
