| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
hi everyone , i have an old school pioneer car amplifier. gm 4200... a superb amplifer.... its RCA input buffer/noise eliminator is fried....however DIN input is working but DIN input is giving huge noise when connected with RCA connection with a latest sony head unit......i tried my luck with a speaker level to rca level convertor and the noise was gone..... but i did not want to use the distorted output of the high level speaker output of the head unit...
so i pulled open the converter which is basically an isolation transformer with a voltage divider network....a 100 ohm resistor with 4.7 ohm in series and the inputs of the transformer are connected at 4.7 ohm resistor......the transformer i tested is 1:4 step up transformer. now i cannot use the same ciructput with rca level output as it has very low impedance input .....amplifier ususally haave 10k + input impedance............please advice how to go about it. |
#2 |
with 43k parallel to tranformer input on a voltage divider network of 430 ohm+43k ohm the bass rolllllssss off...... very low impedance of tranformer at low frequencies means a very small impedance in parallel with 43 kohm...... means a net low resistance and therefore very small voltage output...???? what to do?
| Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted | tiefbassuebertr | Multi-Way | 2 | 20th September 2010 11:20 AM |
| Using isolation transformer as a PSU transformer??? | Yaho | Tubes / Valves | 10 | 27th February 2008 04:16 AM |
| Power Supply Designing using LM317, RC-snubber | okina | Power Supplies | 4 | 12th September 2005 02:17 AM |
| Isolation Transformer | Dick West | Swap Meet | 1 | 30th April 2005 03:28 PM |
| Page generated in 0.07789 seconds (65.38% PHP - 34.62% MySQL) with 10 queries |
