What type of wire for signal in? - Page 5 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 30th September 2011, 04:24 AM   #41
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
ah, ok
I think you may have misunderstood when I said he could disregard the foil
I didn't mean not to connect the shield, ofcourse
what I meant is that the foil is automatically connected to the shield, all way through cable
Old 30th September 2011, 04:39 AM   #42
thaumaturge's Avatar
Originally Posted by tinitus View Post
ah, ok
Tis so. I was refering to not connecting sheild on either end being a bad idea. While you could probably get away with it in many applications a high RF environment soon ferrets out what works and what doesn't. Didn't mean to step on any toes... I quite like it here.
Doc
Noli timere problematum affigit
Old 30th September 2011, 04:48 AM   #43
For the 3-conductor coax that's being used for the potentiometers...where do hook up the foil and braid to? The ground wire?
Old 30th September 2011, 05:04 AM   #44
In that case you are using one wire as send, the second as return and the sheild/ground as ground refference on the pot. The sheild would then be connected to local ground on board end but only to low end of pot on volume control end. A stereo pot can be wired using two 8451 cables. Best is to run one cable per channel with send-return leads inside sheild/ground ref. Rather than using one cable for send and one for return. That might contribute to crosstalk between channels.
Doc
Old 30th September 2011, 05:49 AM   #45
I'm using 2 pots for a ghetto stereo balance thing. =p
So the shield can be hooked up to the ground wire for the potentiometer? But not physically to the pot? Only to the board?
Old 30th September 2011, 06:09 AM   #46
No... The ground at the pot end doesn't normally connect to anything else, such as chassis. The refference point (source connection) is at the amp board end.
Don't know what configuration for balancing you are using, but if it is a board that has common ground reference connections the balance board itself should not connect to chassis ground except through feed cable. The sheild connections should not create a full loop.
====GC_______________GC======= creates a ground loop through chassis (where GC=ground connection)
====NC__________________GC=== or =====GC_____________NC===== is correct. (Where NC=No connection) (=== is twin wires inside)
Doc
Old 30th September 2011, 06:14 AM   #47
I wasn't talking about "chassis ground". I just meant the board's ground plane. By ghetto balance thing, I mean just two potentiometers, each controlling a channel. I'm just asking if the braided shield gets hooked up to the ground wire for the pot. I'll have to make a diagram so I'm understood.
Old 30th September 2011, 06:34 AM   #48
Just this way:
http://i1112.photobucket.com/albums/...doc/volume.jpg
Old 30th September 2011, 07:01 AM   #49
digits's Avatar
I have to say I'm quite fond of the RG-58 type of wire, cheap, shielded, robust and durable.
Old 30th September 2011, 03:28 PM   #50
Originally Posted by thaumaturge View Post
I see that, but if I'm using a 3wire coax...?
Also what happens if I don't hook up the shield to anything?
I mean I could just use the extra 8451 that I have instead of the coax, jw.
Best type of wire for re-cabling AKG 701's .. anyone do this? NOTFRAGILE Headphone Systems 22 26th March 2013 04:36 AM
What is signal level/type at the USB connection? peace brainerd Digital Line Level 4 29th August 2009 08:58 AM
Replacing electroytics in signal path with non-polarised - which type of caps to use? jpcoetzee Solid State 13 15th May 2008 02:12 PM
line out signal wire question fragman56 Everything Else 6 24th November 2006 02:51 PM
signal wire yuval Tubes / Valves 4 21st October 2002 03:26 PM
Copyright 1999-2017 diyAudio
