Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th August 2011, 12:15 PM   #11
analog_sa's Avatar
Originally Posted by janneman View Post
Similarly to your idea but of course not symmetrical and the 1.2V battery certainly allowed for signal zero-crossing at high levels.
Very unlikely that design used the 1.2v directly. It was probably boosted to 36-72v inside that box.
Old 13th August 2011, 12:20 PM   #12
beau2317's Avatar
Teflon, like everything, has a place on the trioboelectric series. Nothing is highly (or even HIGHLY) trioboelectric. It's the difference between the two materials in contact that matter.
So, teflon and silver produce a trioboelectric effect. So do just about any metal and any insulator. Take copper. That is further away from teflon on the trioboelectric series, so copper/teflon should show more trioboelectric effect than silver/teflon. Similarly, common insulators like polypropylene, PVC and polyethylene are also quite close to teflon on the series.
So it seems to me that every interconnect that employs some kind of plastic and some kind of metal will show the effect you are talking about, to some extent or other. Certainly the looser the construction the more the effect is likely to be. Whether it's actually audible is another question.
Perhaps you can link to the anecdote that you posted previously?
Moskido (Hybrid Aikido/Mosfet); Verumecce (biased interconnects). Buffalo III with Unbalancer tube output; Magnepan 3.6R
Old 13th August 2011, 12:24 PM   #13
SY's Avatar
Favorite speaker wire?
“There are no greater liars in the world than quacks, except for their patients.” - Benjamin Franklin
Old 13th August 2011, 12:31 PM   #14
kboe is offline kboe  United States
kboe's Avatar
Hey everyone!
I'm the "someone he knows" who will be posting a full review in a few days, maybe as early as tomorrow.
Bob, would you like me to create a new thread for the review, or post it in this thread?
Till then,
Kevin
Old 13th August 2011, 12:36 PM   #15
beau2317's Avatar
SY : OK - the wire in question was microphonic. But it seems to me that you jumped to the conclusion that it was the Triboelectric effect that was causing this. How do you know that it was this effect and not some other effect?
I have just performed a small experiment : I connected my interconnect to a high gain input on my preamp, much higher than my normal line level inputs. Cranked the volume up to 11 and then tried tapping the interconnect. Actually more like whacking it with a screwdriver.
Result : no detectable microphony. No sound at all noticable through the speaker.
And this is with something like 200 times more gain that I would use for normal "loud" listening. And stimulating the cable with much larger vibrations that loud music would produce.
Old 13th August 2011, 12:37 PM   #16
beau2317's Avatar
Kevin : you can post it in this thread, thanks.
Old 13th August 2011, 12:45 PM   #17
SY's Avatar
That's a good experiment. Try it again with some signal going through it. If all looks OK, you're golden.
Old 13th August 2011, 12:49 PM   #18
beau2317's Avatar
Well I would maybe blow my speakers or at least annoy my neighbors and wife if I used full volume through high gain input.
I can't see how this experiment would work at all. If I use lower gain then it's not likely to show when the music is playing. Just like you don't test for microphonic tubes with music playing, right? You turn up the volume with no music and tap the tubes.
I can do this to humor you, but I can't see the point. Hold on...I will do it now...
Old 13th August 2011, 12:51 PM   #19
SY's Avatar
Nothing fancy, just play a tone through it and tap. If you hear the tone modulate, you need to tighten things up. If not, you're fine.
Old 13th August 2011, 12:52 PM   #20
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
No, I'm quite sure. Just 1.2V.
jan didden
/Another new issue: Linear Audio Volume 3!
Interconnect lengths Skott Construction Tips 4 24th August 2010 12:27 PM
Silver interconnect tubee Parts 0 13th January 2009 08:25 PM
Interconnect cable Midnite Mick Parts 3 3rd January 2007 06:47 PM
interconnect cables dsmkwan Parts 3 29th May 2006 11:15 PM
Interconnect termination hbarki Parts 0 10th April 2004 01:51 PM
Page generated in 0.13015 seconds (78.77% PHP - 21.23% MySQL) with 11 queries
