| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
The analog audio output on my Blu-ray player is too hot and over drives my sound card. The sound card (M-Audio 2496) has no way to control input, so it clips when I feed it into Audacity for ripping tunes.
Is there a passive circuit I can build (cheap) to act as a "volume control"? It doesn't need to come down much. Maybe a pair of pots so I can do balancing as well? I don't want to alter or color the sound, just reduce the intensity. Thanks |
#2 |
As you suggest, a volume control or even just a pair of presets. 10k would be a good choice.
If it's just a "one off" project for occasional use then just chop an old phono lead in half and wire a pot in each (correctly using all three terminals, not just in series which won't work).
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
#4 |
I had a similar problem a few years ago when I started ripping my LP collection to my hard drive, my phono preamp was too hot for the sound card input and drove it to clipping. So, yeah that volume control should work OK. I would also recommend you use RMAA to set the levels, it's free and easy to use. Latest News. Audio Rightmark
Mike |
#5 | |
#6 |
Thanks guys!
A new mini project is born. |
#7 | |
If it were mine I'd build a fixed pad of about 6dB and see (hear) how that goes. Adjustable stuff tends to encourage fiddling. Nice thing about digital media is there is an absolute maximum well defined level the machine can put out and no amount of tweaking record levels will alter it. Hence the fixed pad. G² |
#8 |
I was thinking 10k ?
Actually While I was looking through the pile-o-parts for some pots, I found an old video/mixer from about 25 years ago. A Nady unit, that I had for trying to edit VHS tapes. I put in the output of the Blu-ray player and was able to put it down just enough to stop the clipping. The results don't sound at all bad. But I still want to try "the project" just to see what happens. I do like to fiddle Last edited by Greg M; 6th August 2011 at 11:30 PM. |
#9 | |
G² |
#10 |
I'm having a heck of a time finding a linear, 2 gang, 10k pot.
(Like to get a little Hammond aluminum project box too) |
| best CD audio output from which cheap DVD player? | gychang | Parts | 3 | 26th June 2009 07:26 AM |
| Best Sub - $300 CD or DVD audio new or used? | binarywhisper | Digital Source | 1 | 15th March 2007 05:41 PM |
| Upsampling CD and burning to DVD-Audio DISC | alvaius | Digital Source | 40 | 15th February 2005 09:35 AM |
| CD vs DVD? Audio choice? | Regis | Digital Source | 0 | 18th February 2004 02:24 PM |
| DVD/CD player with Balanced XLR output and volume control | Freddie | Everything Else | 8 | 26th December 2001 07:53 PM |
| Page generated in 0.10748 seconds (79.51% PHP - 20.49% MySQL) with 10 queries |
