| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#31 |
If the Y termination of Q1,2,3 is referring to the package layout i don't see any problem.
I'm preparing an order to Mouser for several small project that i have in plan and i want to include also the parts for LF-01. |
#32 |
I've solved the Y-termination mistery, is related to Hfe:
hFE classification O: 70~140, Y: 120~240, GR: 200~400 What would be the influence over sound of different Hfe ? Last edited by atupi; 17th May 2012 at 07:19 PM. |
#33 |
What all apparatus is required to test this circuit for linearity consistency and whatever possible.
I am on look out to set up a Test bench. Breaking news:- I don't even have an oscilloscope yet !! I am not a pro but an enthusiast who like to see his hands are buzy. |
#34 |
learn to use the instruments you have.
Learn to build accurate instruments that can be relied on for the accuracy you have proved you can build into them. eg, precision stepped dB attenuator. precision stepped decade resistance bank. precision Hamon divider. http://conradhoffman.com/HamonResistor.html precision (simple resistive) Wheatstone bridge. using a resistor to monitor current flow. etc. etc. BTW, combining a Wheatstone Bridge, with a Hamon divider on one side and a stepped precision resistance on the other side allows very accurate resistance measurement over a vast range that a bench DMM cannot approach for accuracy. eg 0r01 to 100M to <0.01% Last edited by AndrewT; 26th May 2012 at 11:59 AM. |
#35 | ||
Thanks AndrewT
I have only known metal film resistor precision-ed to 1% tolerance , is there anything better accessible to Diy'ers like me ? |
#36 |
Ever wondered What an electronics enthusiast would do in weekends when rest of his friends are hanging out in pubs and parties..
I did simulation in Ltspice..(newbie here) Used basic components here to be quick. first is 200khz and second in 2mhz.I hope pictures are self explanatory . what all reasons are attributed for decrease in amplitude.. |
#37 |
Q4, the output-stage PNP, is incorrectly connected - the collector and emitter are reversed. LTSpice doesn't know or care about this - it will apply whatever model it has for the transistor (Gummel-Poon or Ebers-Moll), regardless. You'll probably get a very low-gain (hFE ~=1) transistor in inverted operation, and that's probably why it shows attenuated output.
#38 |
My Bad , I Did not notice the emitter of pnp in negative. when I saw it worked in first run I assumed circuit is alright. (shockingly) it showed me working perfect in 200khz range.I will try again correcting it.
BTW does that implies Lt spice is flawed? I was thinking of designing some filters. Any other better software ? Last edited by jayadev; 3rd June 2012 at 05:51 AM. |
#39 |
LTSpice (or any other simulation program) has no way of knowing if a particular circuit configuration was deliberately intended or an unintentional error. They're all going to simulate it the way it is drawn, but may throw up errors or warnings in some cases. As simulation SW goes, LTSpice is actually very convenient and probably the easiest to use. TI's TINA is another popular alternative.
#40 |
I am Planning to buy 10 pcs of LM318N (Price 1 : INR 78 ) from Kits n spares; very good VFM proposition for a performance Opamp.
I think it is same as LM318m but the package as mentioned for Lf01. |
| Discrete OPAMP | audio-gd | Vendor's Bazaar | 27 | 20th September 2012 04:02 PM |
| Discrete dual-opamp DIP08 module (jcx topology) | linuxguru | Analog Line Level | 8 | 19th June 2011 04:27 PM |
| discrete opamp help | blackpowderaudio | Parts | 0 | 16th December 2009 03:46 PM |
| Mystery module/hybrid | sdman | Solid State | 13 | 18th October 2002 01:30 PM |
