| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
I have been searching for a good line amp with gain around X10, thats also suitable to drive long cables. I stumbled upon this current feedback topology from an old Linear Tech application book, Would this be suitable for a low gain audio line driver? |
#2 |
If it is for audio this would be over-kill. How long is your wire? What are the impedances? Balanced or not? E
#3 |
Hi thanks for your reply, cables are around 10 Meters, poweramp has a 10K input impedance and single ended.
It just seemed with the discreet buffer stage to be an easy to implement and cheep and slightly different approach that may make a nice line amp. Cheers Steve |
#4 |
It's a 3transistor DC coupled amplifier with an output buffer.
The extra is a DC servo to minimise the drift in output offset. If you AC couple this amplifier, you may be able to eliminate the DC servo, leaving a total of 12 transistors for the two channels.
regards Andrew T. |
| 'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' | mikeks | Solid State | 62 | 20th July 2005 08:03 AM |
| Novel? current feedback technique for Class D amplifiers | Rhesus | Class D | 4 | 1st March 2004 07:02 AM |
| Current Feedback Amplifiers Seminar | PGW | Parts | 0 | 7th September 2003 08:18 PM |
| Current feedback in class A amplifiers | marco | Solid State | 3 | 26th September 2001 04:19 PM |
| Page generated in 0.07934 seconds (67.09% PHP - 32.91% MySQL) with 11 queries |
