| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Hello! I need the simplest possible circuitry for a line stage preamplifier/separator able to produce a 0° phase output and a 180° phase output. This is necessary because I need to drive a single-coil subwoofer with a classic stereo amplifier.
Thank you very much. |
#2 |
Use an opamp to invert the phase.
This same circuit can be switched so that the opamp operates as a non-inverting and as an inverting stage. This way the single opamp amp acts as a buffer and as an optional signal inverter. The circuit is shown in Parr's "How to use opamps" fig 2.27 and is likely to be somewhere in this Forum. Electronic switching of phase is shown in fig 2.28
regards Andrew T. Last edited by AndrewT; 21st July 2011 at 02:36 PM. |
#3 |
If you can use a gain of +1 and -1 you might look into a split-load inverter, familiar to tube guys as a "paraphase" or "concertina" stage. To implement one with DC coupling maybe think along the lines of a complementary folded cascode with equal loading in the source-to-ground and drain-to-ground.
Good fortune, Chris |
#4 |
Thank you for these indications, but can you give me a scheme? Better if using fet or jfet..
#5 |
You can use TI's drv134/drv135. Those don't need external parts and are cheap.
http://focus.ti.com/lit/ds/symlink/drv135.pdf |
#6 |
Here's an example of a paraphase "split-load" inverter made with a triode, Fig. 2, and with JFET folded cascode, Fig. 1. Trims are for DC offset. Equal R's give equal output magnitudes.
Folded cascode paraphase.jpg For most uses the current sources can be resistors. All good fortune, Chris |
#7 |
If you dont need any power gain the simplest thing would be to use an audio transformer with a secondery center tap. One leg to centre will be +ve the other -ve.
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 12:37 PM |
| Aleph Phase Inverting / non inverting | macka | Pass Labs | 9 | 22nd February 2006 07:01 PM |
| inverting / non-inverting op-amp circuits | Learnincurve | Solid State | 11 | 21st January 2005 05:40 PM |
| Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB | Alexander Rice | Chip Amps | 9 | 27th March 2004 06:53 PM |
| Inverting/non-inverting Op-amp Inputs !!!help!!! | IIR | Solid State | 17 | 11th May 2002 02:02 AM |
| Page generated in 0.08728 seconds (74.13% PHP - 25.87% MySQL) with 11 queries |
