| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#21 |
Speakerholic
Good, not in a car.
B switch is something from the old days. The caps and coils you need are linked to in post 16. Parts Express is only 5 states away from you. Most important is the question about operating your source. |
#22 |
i connect the amp in crossover..
#23 |
Speakerholic
Now I am confused. Please draw a picture of what you mean.
I am going home now so I will be away for a bit. |
#24 |
umh sori Cal...i connect the input of cross over R L + - sign of ampli
#25 |
Speakerholic
Yes, I want to know how you plan to run two amplifiers from one source without a pre-amp.
You have a source, let's call it a CD player. How does it get to two different amplifiers. ie: one for the main speakers and one for the woofer you have. It has to be split somehow. If you use a Y adapter then, if you don't have a pre-amp, you will have to adjust the volume of the woofer and main speaker separately. What amps do you have? |
#26 |
i only have 1 amp Cal
#27 |
Speakerholic
OK, I am busy for the rest of the evening so I can't help anymore. Maybe tomorrow.
#28 |
Speakerholic
It will be hard without a second amp. The DVC are 4 ohms each so unless your amp can take that low of a load combined with your main speakers you will probably have to get a plate amp to do this.
#29 |
i see i need a preamp?
#30 |
Speakerholic
I was out playing tennis.
If your amp/receiver has a subwoofer RCA out then you need a plate amp. Show us a picture of the back. |
| ucd 25 watts to 1200 watts using 2 mosfets | andrewlebon | Class D | 3548 | 28th May 2013 12:00 PM |
| help pls...about crossover watts | ian707 | Chip Amps | 0 | 7th July 2011 10:22 PM |
| Pls. help - Realistic Minimus 7 Crossover Questions | CR007 | Multi-Way | 7 | 29th January 2009 01:24 PM |
| Newbie - Designed crossover - Pls let me know if its okay | Ronnie22 | Multi-Way | 12 | 11th August 2005 08:30 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
