Go Back   Home > Forums > Source & Line > Analog Line Level
Old 5th July 2011, 02:29 PM   #1
graygem is offline graygem  United States
Default multiple feedback low pass filter question
All the multiple feedback lowpass filters I see are inverting type. Is it possible to do a non-inverting multiple feedback low pass filter?
Just something that I keep asking myself.
Professional Newbie.
Old 5th July 2011, 03:13 PM   #2
No, MFB filters are inherently inverting. If you're thinking of trying to input signal to non-inverting input of MFB filter, it won't work correctly. You must correct signal inversion elsewhere in the design. One way to accomplish that is to use another inverting circuit to "un-invert" final output, could be an inverting buffer or amp, or in the case of a 4th order lowpass for example, use two MFB filters in series, I've done that in some of my projects.
Mike
Old 5th July 2011, 03:35 PM   #3
Thanks, that was my thoughts as well.
Old 5th July 2011, 04:31 PM   #4
So, how would I make an inverting unity gain amp with a 28Hz roll off in front? Below is the non inverting buffer they use. What should I do to make into inverting amp?
Old 5th July 2011, 04:40 PM   #5
DF96 is online now DF96  England
I may have misunderstood the question, because the answer is obvious? Use an inverting op-amp configuration, with a capacitor in series with the input resistor.
Old 5th July 2011, 04:52 PM   #6
I need an inverting amp from the non inverting pictured. I know it is very simple but I'm still learning.
Old 5th July 2011, 05:09 PM   #7
OK. Like I said, use the inverting configuration with a capacitor.
Old 5th July 2011, 05:22 PM   #8
Like this?
Old 5th July 2011, 05:26 PM   #9
Here ya go.
Mike
Old 5th July 2011, 05:34 PM   #10
Davey is offline Davey  United States
I thought you were interested in a non-inverting.....multiple feedback.....and low-pass filter?
Now, you've got an inverting.....non-multiple-feedback....high-pass filter.
Dave.
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
Low Pass Filter question synthius Chip Amps 18 28th February 2008 12:13 PM
Low pass filter? happyb Car Audio 5 11th December 2006 09:47 PM
simple low pass RC filter noob question mr.duck Parts 13 22nd July 2006 02:16 AM
know of a web-based calculator for a multiple feedback band pass filter? travis Everything Else 2 13th August 2003 05:08 AM
Page generated in 0.09160 seconds (79.37% PHP - 20.63% MySQL) with 11 queries
