Swapping Op-Amps... you have checked to see it's stable haven't you ? - Page 12 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 24th April 2013, 07:50 AM   #111
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Originally Posted by dmccoach View Post
Thank you all - I can't find a schematic for the (older, or original not the new "Super") Eastern Electric Minimax DAC but I will continue to look. The LME9940 is a "common" (DIY, smart? effective? is another issue) swap (with the brown-dog adapters) for the stock I/V conversion stage and output. The stock opamps are I/V 2 x NE5532. After this opamps, there're 2 outputs stages, one based on a single tube (12AU7) and other SS with the opamp NE5534.
Scanning the net reveals many- many - comments about them (LME49990) running hot (in all kinds of audio circuits. It is *apparently* common. The specs allow for a range up to about 185F, but I didn't understand why my right and left channels seem to run at different temps. It could be my laser temp. reader is not consistently hitting the hot-spot on the U2 and U7 due to the angle at which I have to take a reading.
OPERATING RATINGS(1)
Temperature Range
TMIN ≤ TA ≤ TMAX 40C ≤ TA ≤ 85C
Supply Voltage Range 5V ≤ VS ≤ 18V
But, the LME4990 run so hot (occasional reading up to 140F on U1) that I might worry about putting the Minimax lid back on top and driving ambient up inside the unit.
If this is running as a 'summer' on a current output DAC, then what you may be seeing is stray capacitance between the summing node and GND that's causing it to break into oscillation. Also, keep in mind that any noise coupled between the actual summing point (i.e. where the resistors meet) and the inverting input will be amplified by the full loop gain of the opamp - and in the case of those LME devices, this could be over 100 dB at a few kHz
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 21st July 2014, 09:08 PM   #112
Great post about Op Amp "Singing" (Oscillation)
Its more years than I care to remember - however, advise about Op Amp compensation
can often be obtained from application notes or even data sheets themselves.
The NE5532 is an Op Amp that uses bi polar transistors
Many of the Other Op Amps mentioned here have jFET's on the input.
Zin of an Op Amp with a jFET input stage would be significantly different.
Rin of a jFET Op Amp would be in the order of 10^12 or 10^13 ohms
and Cin would be in the order of 10 pF
Its important to remember that at the x1 setting, a scope probe adds about 15pf // 1 M ohm.
So be careful not to disturb the very circuit you are trying to measure.
Using the x10 setting on the probe will help.
However, a wire added to the scope probe will act like a receiving antenna.
If its place near the circuit it should pick up any "singing"
Mooly was bang on showing oscillation was hiding in the blurred trace.
One other comment - the chassis of a scope is earthed.
So a scope can only measure voltages with respect to 0 v.
Old 21st July 2014, 09:24 PM   #113
To be clear, the AD797 is a bi polar Op Amp too.
AD797 datasheet, Pinout ,application circuits Ultralow Distortion Ultralow Noise Op Amp
Old 22nd July 2014, 05:53 PM   #114
Mooly's Avatar
Good point on the scope leads introducing extra capacitive loading which can in some cases tip a circuit over the edge. Worst offenders are the simple "coax and crop clip" type leads that are surprisingly common. If in doubt then it can pay to solder a lowish value resistor to the point of interest to provide isolation and then probe the free end of that.
Old 5th August 2014, 05:28 AM   #115
SyncTronX's Avatar
Originally Posted by Bonsai View Post
Here is a low cost oscillation sniffer. You can build it into an old marker pen case. It usefully covers c. 100KHz to a few MHz - just where there are usually problems in audio.
Bonsai,
Do you have a higher resolution of the schematic?
Something must be wrong with my PDF viewer because
at 300 percent I still can't read it.
-- Sync
Old 5th August 2014, 05:44 AM   #116
Bonsai's Avatar
I'll try again when I get home Sync. I am travelling on the road this week.
bonsai
Old 12th November 2014, 07:18 AM   #117
MaccAu is offline MaccAu  Australia
MaccAu's Avatar
Send a message via AIM to MaccAu Send a message via MSN to MaccAu Send a message via Yahoo to MaccAu Send a message via Skype™ to MaccAu
Thanks Mooly , i thought it was just pull and replace. I think the LM4562 is pretty compatible
1980s are rad
Old 12th November 2014, 07:46 AM   #118
Mooly's Avatar
Yes, the 4562 should be fine for replacing 5532's and the like... which I think is what you are doing.
Old 12th November 2014, 08:14 AM   #119
MaccAu's Avatar
Thanks , I am Mooly, and the specs are pretty close. The 4558 i am replacing also, as is in the audio section of the PCB
1980s are rad
Old 12th November 2014, 08:26 AM   #120
Mooly's Avatar
You need to be sure the 4558 is audio related in its use. It seems odd to use a mediocre opamp along with 5532's.
Why do solid state guitar amps need so many op amps? razorrick1293 Instruments and Amps 2 8th June 2011 10:06 AM
Op amp swapping liquias Digital Source 37 29th October 2010 07:45 AM
Burr Brown op amps,in amps,power op amps for sale magneticnorth Vendor's Bazaar 1 23rd September 2010 10:50 PM
swapping op-amps in a vestax pmc-55 sr126 Chip Amps 4 26th June 2008 04:23 PM
FS PA02 Power op-amps +/- 18v, 5 amps modifry Swap Meet 0 11th August 2004 07:45 PM
Copyright 1999-2017 diyAudio
