Swapping Op-Amps... you have checked to see it's stable haven't you ?
Old 21st March 2013, 11:16 AM   #101
dmccoach is offline dmccoach
Thank you all - I can't find a schematic for the (older, or original not the new "Super") Eastern Electric Minimax DAC but I will continue to look. The LME9940 is a "common" (DIY, smart? effective? is another issue) swap (with the brown-dog adapters) for the stock I/V conversion stage and output. The stock opamps are I/V 2 x NE5532. After this opamps, there're 2 outputs stages, one based on a single tube (12AU7) and other SS with the opamp NE5534.
Scanning the net reveals many- many - comments about them (LME49990) running hot (in all kinds of audio circuits. It is *apparently* common. The specs allow for a range up to about 185F, but I didn't understand why my right and left channels seem to run at different temps. It could be my laser temp. reader is not consistently hitting the hot-spot on the U2 and U7 due to the angle at which I have to take a reading.
OPERATING RATINGS(1)
Temperature Range
TMIN ≤ TA ≤ TMAX –40C ≤ TA ≤ 85C
Supply Voltage Range 5V ≤ VS ≤ 18V
But, the LME4990 run so hot (occasional reading up to 140F on U1) that I might worry about putting the Minimax lid back on top and driving ambient up inside the unit.
Old 21st March 2013, 12:37 PM   #102
qusp is offline qusp  Australia
qusp's Avatar
actually the lme isnt exactly the best choice for IV, its a great chip for low noise VAS but not really fast enough for a ES9018 trans-impedance stage IMO. it seems its been chosen due to its (well earned) reputation as a nice low noise opamp for not much money, rather than being useful for the job at hand.
that being said, being on an adapter in a socket that isnt really very well decoupled (not close enough and only using audiophile approved leaded film caps, rather than something usefully small and low inductance...) the right side is very close to the clock, could mean you are picking up stray RF. is it the one on the right in this pic next to the clock thats hotter? I wouldnt worry too much about a tiny opamp heating up the chassis ambient too much, but if they really are that much different, then there may well be something undesirable going on
Old 21st March 2013, 01:01 PM   #103
Thanks would you recommend anything over the I/V stage stock NE5532?
Old 12th April 2013, 01:37 PM   #104
RickDangerous is offline RickDangerous  Mexico
Originally Posted by SY View Post
Get a scope. Seriously. Why in the world would someone try to do electronics without the basic tools? May as well try to get by without a soldering iron.
@Mooly : very interesting, thanks for posting.
How much is a used scope, and what sort of things should one look out for when buying one?
Thx
Old 12th April 2013, 02:30 PM   #105
Mooly's Avatar
I would always recommend an analogue scope (using a CRT) and one that has (and everyone has their own ideas here) at least 20 to 30Mhz bandwidth with dual trace. Higher if you can get it but if not that will sufficer for most diy (and more) needs.
No idea on prices tbh although auction sites list dozens
Old 12th April 2013, 03:19 PM   #106
Audio Maniac is offline Audio Maniac  Brazil
Default LME49990
I haven't detect temperature issues with the LME49990 used in I/V of my Minimax.
There may be more suitable opamps for the function, but it's the best direct drop option I've already tried. I have tried the opamps bellow that are ranked in my preference order:
- LME49990 (similar to 49720, but more smooth highs)
- LME49720
- NE5532
- OPA2604
For output, the model chosen is ADA4627-1BRZ.
Old 13th April 2013, 07:44 PM   #107
audiofilaid is offline audiofilaid  United States
audiofilaid's Avatar
Nice thread and one I was looking for as I'd like to swap out the op amps on my MF V-VLPS. I don't own a scope and wondering if this might be an issue? I had "assumed" I could buy the op amps and simple replace them and possibly have a new sound for my amp-turntable??
Old 15th April 2013, 05:46 PM   #108
Mooly's Avatar
Instability is always a possibility swapping opamps and is why you should always check with a scope. Without that check you just don't know for sure and as this thread mentions at the start, its not always audibly obvious that a device is oscillating.
Old 24th April 2013, 02:48 AM   #109
mikej56 is offline mikej56  United Kingdom
The best thread I've read in a long time - now where did I bury that scope?
Old 24th April 2013, 03:23 AM   #110
jcx is offline jcx  United States
new Rigol 'scopes and others have become ridiculously high value propositions in just the past year or so - with GHz sample rate the 50 MHz dual channel sufficiently oversamples for a "analog feel"
buying a new, working 'scope seems like a very practical way to go today
Swapping Op-Amps... you have checked to see it's stable haven't you ?Hide this!Advertise here!
Why do solid state guitar amps need so many op amps? razorrick1293 Instruments and Amps 2 8th June 2011 11:06 AM
Op amp swapping liquias Digital Source 37 29th October 2010 08:45 AM
Burr Brown op amps,in amps,power op amps for sale magneticnorth Vendor's Bazaar 1 23rd September 2010 11:50 PM
swapping op-amps in a vestax pmc-55 sr126 Chip Amps 4 26th June 2008 05:23 PM
FS PA02 Power op-amps +/- 18v, 5 amps modifry Swap Meet 0 11th August 2004 08:45 PM
Copyright ©1999-2017 diyAudio
