| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
I want to build a basic stereo mixer for my pc, so I found this indestructible that has resistors in between each source and that got me wondering if I could use a dual pot instead and have control over the input volume. Maybe I can use this for a multi mic setup. What pot should I use and will my idea work?
#2 |
You can have dual pots as it is stereo.
Look up dual pot at any electronics supplier. RS Components | Electronic and Electrical Components Maplin Electronics : External Hard Drives | Music | CCTV Farnell United Kingdom | world-leading distributor of electronic and maintenance, repair and operations products.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
you should put the pots across the input of the mix matrix.
a 10k pot should be good enough for your applications. a schematic with formulas for creating a passive mix matrix: |
| DIY DJ mixer | Bricolo | Analog Line Level | 34 | 7th January 2011 12:00 PM |
| DIY 4 Channel Stereo Mixer | rtgree01 | Analog Line Level | 2 | 14th December 2010 03:06 AM |
| diy dj mixer | laki101 | Analog Line Level | 2 | 17th November 2010 12:17 PM |
| ESP Project 94A, What am I doing wrong? (Simple Mixer) | audiomodder | Analog Line Level | 1 | 10th January 2010 08:47 PM |
| Need help with my first project; 7x6 headphone/monitor/matrix mixer | jumpfroggy | Headphone Systems | 5 | 10th January 2008 07:36 AM |
| Page generated in 0.08455 seconds (68.70% PHP - 31.30% MySQL) with 11 queries |
