Go Back   Home > Forums > Source & Line > Analog Line Level
Old 17th June 2011, 12:20 PM   #1
Reno1 is offline Reno1  United Kingdom
Default Mic Preamp Buffer
Hi I am building a mic preamp using the THAT 1510 preamp however I am in need of a suitable buffer to place after my volume pot to got to my tone control circuit any suggestions
Old 17th June 2011, 12:32 PM   #2
SY's Avatar
Single ended or balanced?
“There are no greater liars in the world than quacks, except for their patients.” - Benjamin Franklin
Old 17th June 2011, 06:04 PM   #3
Single Ended
Old 17th June 2011, 06:10 PM   #4
SY's Avatar
Then a buffer is pretty simple. If you like tubes, an ECC88 cathode follower will work beautifully (if well designed) without adding significant noise. In the opamp world, a unity-gain-connected OPA2134 will give you much bang for buck.
Old 17th June 2011, 08:07 PM   #5
Thanks for the help any recommended circuits preferably using op amps
Old 17th June 2011, 09:29 PM   #6
Show us what you have now and what you want to do. Schematic diagramms are the bablefish of electronics. E
Old 17th June 2011, 09:34 PM   #7
SY's Avatar
Also important are specifications for:
*Required overall gain
*Gain of the first stage
*Output level
Old 18th June 2011, 09:46 AM   #8
Hi I am basically using the circuit provided on the website for the THAT 1510 preamp THAT Corporation 1510-1512 Audio Preamplifier ICs
I will be using a 50k pot from the output which will feed the tone control circuit.
The tone control will either be a 3 band baxandall circuit, or a 3 band control with sweepable mid. I will probably use the second one i will post a picture when i can find it thanks
Old 18th June 2011, 10:11 AM   #9
SY's Avatar
The important missing element is the sensitivity of what you're driving. Some line inputs have one or two volts of sensitivity (max input), others more like seven or eight volts. Other question would be, what does the buffer have to drive? If it's a meter or so of coax, just about any good opamp (like a 2134) that's unity gain stable, strapped as a follower (output tied back to the inverting input, input taken to the noniverting input) will work fine. A 100 ohm resistor at the output will help ensure stability. This all assumes something like a 10k input impedance- if you have a 600 ohm load, we'll need to get slightly fancier.
Old 18th June 2011, 10:11 AM   #10
Why an additional volume control? You can use a potentiometer in place of the gain setting resistor Rg, use a capacitor in series with it. I see no need to add gain and the reduce it.
Roger
Need a Piezo buffer with Balanced, mic level output bigredlevy Instruments and Amps 3 30th April 2012 03:22 AM
Good Buffer/Preamp circuit for electret mic Caleb Chia Instruments and Amps 1 4th May 2011 10:44 AM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
'Tube' preamp bad for measurement mic? also Apex mic question morbo Multi-Way 10 23rd March 2005 10:19 AM
What mic preamp for Behringer testing mic The Paulinator Multi-Way 1 6th April 2003 07:02 PM
Page generated in 0.10085 seconds (75.97% PHP - 24.03% MySQL) with 10 queries
