| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Does anyone have any experience with the THAT 1510/1512 op-amps. Would they be suitable for using in a phono-preamp, just for the need to try them out. |
#2 |
I've used them a good bit as mic preamps.
I imagine they would work fine for a transformer coupled moving coil. They would be less than optimal for a direct moving coil output. They are designed for low impedances so would not be a good match for typical moving magnet cartridges that typically want to see about 47K/200pF. Les L M Watts Technology |
#3 |
Mic pres, and Mixing buffer amp, and master outs.
I used the VCA's too. They're descent. This company was with DBX Co. ( used to be DBX Semiconductor) |
#4 |
They're balanced in, so you'd want to set up your phono cartridge and cables that way to take advantage. At high gain, the noise voltage is actually pretty low (1.8nV/rt Hz), so they'll work with a lot of MCs.
“There are no greater liars in the world than quacks, except for their patients.” - Benjamin Franklin |
| Why do solid state guitar amps need so many op amps? | razorrick1293 | Solid State | 2 | 8th June 2011 10:06 AM |
| Burr Brown op amps,in amps,power op amps for sale | magneticnorth | Vendor's Bazaar | 1 | 23rd September 2010 10:50 PM |
| Small Qtys of THAT Products 1510 2180 | mediatechnology | Swap Meet | 0 | 15th April 2006 01:56 PM |
| FS PA02 Power op-amps +/- 18v, 5 amps | modifry | Swap Meet | 0 | 11th August 2004 07:45 PM |
| Op Amps in Solid State Guitar Amps | MrGuitardeath | Instruments and Amps | 1 | 11th February 2004 07:43 PM |
| Page generated in 0.08089 seconds (70.93% PHP - 29.07% MySQL) with 10 queries |
