| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#11 |
Hi, attached is the corrected schematic.
Note: the opamp in the schematic was just a random one to get the thing to simulate - a type recommended is a TL071 . Thanks to Mooly and Bonsai for their input - plenty of things to consider in future designs! |
#12 |
The opamp is fine as drawn.
D1 that has appeared. Very sensible for battery powered equipment. Only comment is that it robs the circuit of around 0.7 volt... and on battery thats important. You could add a diode in inverse parallel across the supply (using say a In4001 type) that would protect the circuit. Depending on the battery and how much curent was available that could overheat the 10 ohm... Personally I would go with inverse parallel and keep as much voltage as possible for the circuit.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#13 |
Is that also called a diode snubber?
#14 |
A diode snubber usually refers to a diode across an inductive load such as a relay coil etc.
I don't know a diode across the supply has an official name tbh Reverse polarity protection I guess.
| First Project - Seas Induss Kit - Suggestions/Improvements | sirizak | Multi-Way | 12 | 24th February 2011 08:52 PM |
| B1 passive + Pearl 2 phono preamp + DCPS improvements? | intrator | Pass Labs | 0 | 17th December 2010 07:46 PM |
| Bottlehead Foreplay III improvements, suggestions, alternatives? | CoolJazz | Tubes / Valves | 4 | 3rd December 2009 04:02 PM |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
| Preamp suggestions | r0cket- | Solid State | 1 | 23rd September 2003 02:05 PM |
