Go Back   Home > Forums > Source & Line > Analog Line Level
Old 4th June 2011, 07:56 PM   #1
BillDitwell's Avatar
Question Please help: building a notch filter
I am currently building an active version of Zaph's Hi-Vi B3S single driver speakers (Zaph|Audio), with a built-in Dayton DTA-2 amplifier circuit.
Using parametric EQ software on my PC, I recreated the response curve of Zaph's passive filter, and the results sound amazing (seriously; $13 drivers, a $22 amplifier and $5 MDF boxes have no business sounding that good!). Now if I could just figure out how to build the same filter with resistors, capacitors and op-amps, I'd be one happy, cheapass audiophile.
I already found a very well-explained and workable BSC filter circuit (Baffle Step II), so that's one less worry.
I am still at a loss when it comes to the 8.1KHz notch filter. I found many examples of circuits for such filters, but they were designed to completely remove a band of frequencies, whereas I only need to slightly lower the gain. Basically I need 8.1KHz, -8dB, Q=3 (about 1/3 octave bandwidth if I'm not mistaken). The simpler the circuit, the better. Any suggestions?
If I manage to pull this off, then I'll be sure to post a detailed writeup with pics and all.
Thanks in advance.
Old 4th June 2011, 08:03 PM   #2
It sounds like you just need one section of a multi-band equalizer. Do a search on "equalizer circuits" and you'll find many. They usually have a pot for boost or cut- either set what you need with a pot, or replace it with fixed resistors.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 6th June 2011, 03:42 AM   #3
If you are looking to make an active notch filter, I can supply you with a printed circuit board and a bill of materials for creating a notch filter at that frequency and Q. The circuit will only use 1/2 of the PC board, a dual op amp, and a few parts. The response should be like this:
The above plot is from a simulation I put together of the as-built circuit using real world components having Fc=8.1k Hz and Q=3. There is a slight gain loss of about -0.5 dB.
I have developed the board design so that a range of active circuits can be created using the same board, depending on how it is populated with components. You can design it for whatever frequency and Q you want, if you decide to modify the notch frequency or depth for instance, or want to use the other half for a HP or LP filter, delay, etc. You will need to solder all the parts to the board and provide a regulated power supply to use it.
Send me a PM if you are interested.
-Charlie
Old 7th June 2011, 11:24 PM   #4
Conrad: thanks for the great suggestion. I knew there was an obvious solution, and that I just wasn't searching for the right one! Looks like I'll just have to build a gyrator filter circuit (Guitar Pedals: Gyrator Filter Calculator), then pad it to get the desired depth.
Charlie: thanks for the offer, but for now I'd rather try "rolling my own" with a generic PCB. I'll let you know if I change my mind.
Notch Filter Design - Seas L21 (H0955) Breakup Modes:Single or Multiple Notch Filters dtm1962 Multi-Way 10 8th February 2010 02:17 PM
Notch filter godless Multi-Way 5 22nd April 2008 09:26 AM
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
notch filter help omni Multi-Way 14 23rd July 2007 01:11 AM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 01:27 AM
Page generated in 0.08646 seconds (72.21% PHP - 27.79% MySQL) with 10 queries
