Go Back   Home > Forums > Source & Line > Analog Line Level
Old 2nd June 2011, 03:07 AM   #1
Default Improved LDR Volume Control
Hi All. I have been following the thread on the “Light Speed” and other LDR controls. There are a few issues of note.
1/ Source impedance is relatively low especially around the mid range.
2/ Output impedance is too low for some high impedance input amplifiers.
3/ Despite the “No Pot’ in the signal path, there are at least two in the LED illumination circuit.
The following design has no Pots at all, minimum source impedance of 27K and output of around 21K which may still be too low in some cases.
I’ m calling it a Shutter light for want of a better name. A shutter is moved across four 25mm long tubes housing the LDRs via a 270 deg cam. The four LEDs are not in line with the LDRs but offset toward the centre point. If they were in line, the source impedance would drop into the 100’s of ohms area in the centre of travel (135 deg). At the centre point both shunt and series LDRs are relatively shaded and both have 13K or so of resistance. As the shutter moves from the centre; move light falls on one and less on the other increasing the source impedance.
Alignment and channel matching is done simply by shoving the LED’s one way or another. Response can also be altered by moving them closer to the centre, or just the series one to create a log response. I’m still messing about with this and have yet to do any listening test. You thoughts?
never re-invent the wheel
Old 2nd June 2011, 03:12 AM   #2
Default Some graphs
Attached images are of the wiper transfer. A 5 volt supply connected across the LDR's and the control moved in 10 deg steps.
The R curve is the sourse impedance across the LDR's
Old 1st July 2011, 06:18 PM   #3
mcspack is offline mcspack  United States
Interesting, how is this project coming? Any listing impressions yet compared to standard lightspeed? I'd love to see some more pics of the insides of this device as well as a schematic?
thanks
MC
Old 2nd July 2011, 08:01 PM   #4
AndrewT is online now AndrewT  Scotland
I am confused with the way you describe the impedances.
The Source impedance is the output impedance of the Source as seen by the Receiver.
The output impedance is that seen by the Receiver.
The Source has an output impedance
The receiver has an input impedance
The LDRs have a source impedance and an input impedance.
The Source sees the input impedance of the LDRs.
The Receiver sees the output impedance of the LDRs.
regards Andrew T.
Old 12th July 2011, 02:51 AM   #5
Hi Andrew. To avoid confusion just consider the LDR network as a standard pot. The plot on the left is the resistance through 270 deg of rotation Across the pot. i.e. top to bottom (the connection to the source, CD etc)
The plot on the right is of the resistance through 270 degs of the wiper to the bottom or earth of the pot ( connects to the amplifier)
Old 12th July 2011, 02:54 AM   #6
Hi MC. Sorry for the delay. Have been away working and haven't got around to doing some serious listening as yet. Will post some more images of the unit apart to give you an idea. I also have CAD drawings I used to construct it, if you are interested.
Simon
Old 12th July 2011, 03:09 AM   #7
Default Internal Pic
Here is a pic of the unit. The left half has the LEDS and 270 deg log taper. The right is the shutter and LDR light shafts.
Old 12th July 2011, 04:21 AM   #8
I understand the concept of your design, but if I'm seeing it correctly, it looks like both LDRs are operating exactly the same way, that is it appears they increase and decrease resistance together, whereas one should increase awhile the other decreases. Am I seeing it right?
Mike
Old 12th July 2011, 04:48 AM   #9
Hi Mike. In the photo you are seeing the bottom half of both channel LDR tunnels. The other two are hidden under the shutter. Would a pic of the shutter half way help. If so I can post one.
Simon
Old 12th July 2011, 05:00 AM   #10
Default Image for Mike
Mike. Here is a pic of the shutter at the half way point and of the light tunnels with the LDRs in the ends.
Preamp: Comparing LDR and buffered LDR Dr.H Analog Line Level 7 5th October 2011 01:29 AM
Paul Haynes LDR Volume and Balance with Remote Control (lightspeed, Lighter Note) ua100k Swap Meet 2 26th April 2011 03:00 PM
LDR volume control alternative seanvn Solid State 3 17th April 2011 07:00 AM
Replacing broken volume control with digital volume control Gunawan W Solid State 19 15th December 2010 10:46 AM
WTB: LDR-based volume control / pre jdubs Swap Meet 7 2nd December 2010 01:50 AM
Page generated in 0.11487 seconds (80.27% PHP - 19.73% MySQL) with 11 queries
