Jfet folded cascode with diamond buffer opamp
Old 27th April 2013, 09:18 PM   #31
sonnya is offline sonnya  Denmark
sonnya's Avatar
I Will test with ssm2212 tomorrow .
The input bias current Will be less than 5uA.
- Sonny
Old 27th April 2013, 09:45 PM   #32
sonnya's Avatar
Just a shot of the difference on input and output on the squarewave signal.
Lightblue is the input.
Old 27th April 2013, 10:51 PM   #33
sonnya's Avatar
I have tested the JFET opamp with NPN pair instead of jfet's.
Some of the data is:
  • Less than 2mV input offset
  • less than 4uA input offset current
  • Distortion 10 times lower at 10KHz into 220R load
The picture below is as with all the other measurement
  • 47pF compensation
  • 680mVrms out
  • 10KHz Sine
  • 0dB gain
Distortion is 0.0018% - Generator is: 0.0013%
Old 28th April 2013, 09:45 AM   #34
R.I.P.
still the post1 schematic?
regards Andrew T.
Old 28th April 2013, 12:02 PM   #35
sonnya's Avatar
No, it is changed a bit.
See attachment.
instead of folded cascode, i use current mirrors now. But performance is exactly the same.
File Type: jpg fft 10KHz 1K load 11xgain NPN pair.jpg (118.4 KB, 153 views)
Old 28th April 2013, 12:34 PM   #36
sonnya's Avatar
Here is the schematic of Bipolar version of the Jfet opamp
Jfet folded cascode with diamond buffer opampHide this!Advertise here!
Folded Cascode in the Making wrenchone Solid State 11 6th March 2010 01:11 AM
All FET folded cascode driver for "JLH"-buffer with no GNFB revintage Solid State 10 29th January 2010 09:58 AM
folded-cascode FET/opamp MC phono Werner Analogue Source 33 17th January 2010 10:22 AM
folded-cascode FET/opamp MC phono Werner Analogue Source 24 12th October 2006 10:07 AM
folded cascode the_tool Chip Amps 1 27th June 2006 09:53 PM
