Jfet folded cascode with diamond buffer opamp
Old 27th May 2011, 07:29 AM   #11
sonnya is offline sonnya  Denmark
sonnya's Avatar
Default jfet opamp module simulation data
Hi all.
I have attached the simulation data.
Old 27th May 2011, 07:34 AM   #12
sonnya's Avatar
The sim data should speech for them self.
The supply voltage is +/-15V
When compensation is added it is added from "COMP" to V-.
Source:50Ohm.
Feedback for x11:10K+1K
Feedback for x101:10K+100R
Feedback for x1:1K
The picture "CLGx11-47pfcomp-22pF-1vppstep" is a 220pF load and not 22pF
File Type: jpg CLGx11+47pFComp+22pF+1Vppstep - sim B.jpg (183.3 KB, 43 views)
File Type: jpg CLGx11+47pFComp+220pF+1Vppstep - sim A.jpg (198.9 KB, 43 views)
Old 27th May 2011, 08:08 AM   #13
sonnya's Avatar
Default FFT 1KHz out
1Kohm Load at 1KHz and 1Vpp and 11Vpp.
Old 27th May 2011, 09:15 AM   #14
MiiB is offline MiiB  Denmark
How does it sim at 20 KHz..??
Old 27th May 2011, 10:25 AM   #15
sonnya's Avatar
Hi MiiB.
Here the 20KHz at 1Vpp and 11Vpp is shown also with 1K load.
I am satisfied with result myself.
- Sonny
Old 28th May 2011, 05:17 AM   #16
sonnya's Avatar
Default Noiselevel of jfet opamp
The last one. with noise levels at 1x 11g gain.
- Sonny
Old 29th May 2011, 05:02 AM   #17
sonnya's Avatar
Did you get what you asked me about?
Old 29th May 2011, 05:55 AM   #18
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Have you considered a little more voltage drop than provided by D2?
Old 29th May 2011, 06:44 AM   #19
sonnya's Avatar
There are two versions of it.
The first one, which you refer too with folded cascode and the one with wilson mirror in post 7 (Easier to implement on the small pcb).
I have tried with a LED as D2 as weel for simulation. And there is no difference. But we also have .65V CE drop across U5-A and U5-B. This also works good for current mirrors and hawksford cascode which i use in my CFB amp.
Old 21st June 2011, 10:33 PM   #20
sonnya's Avatar
Now i have had time to order pcb and stencils.
They will arrive in week 27.
I will make a motherboard for them to test them.
Jfet folded cascode with diamond buffer opampHide this!Advertise here!
Folded Cascode in the Making wrenchone Solid State 11 6th March 2010 01:11 AM
All FET folded cascode driver for "JLH"-buffer with no GNFB revintage Solid State 10 29th January 2010 09:58 AM
folded-cascode FET/opamp MC phono Werner Analogue Source 33 17th January 2010 10:22 AM
folded-cascode FET/opamp MC phono Werner Analogue Source 24 12th October 2006 10:07 AM
folded cascode the_tool Chip Amps 1 27th June 2006 09:53 PM
