Go Back   Home > Forums > Source & Line > Analog Line Level
Old 7th May 2011, 11:32 AM   #1
Default Mic pre amp Problem
Hi folks,
I need some help in the mic amplifier where I have to find a suitable op amp. My specs are an input of max amplitude of 150mV from mic and an output of 3v max amplitude from op amp. The output bandwidth from microphone is stated to be from 200Hz to 20kHz. The op amp will be supplied from +12V and -12V (dual supply). I have a good idea on parameter i have to consider like bandwidth, slew rate etc in fact I decided to work with OPA2134.
There were some hints in class regarding the addition of rc filters but the thing is that in the problem it doesn't specify any dc offset in the input and so I can see the need for a coupling capacitor at the input. And when it comes to low pass do you think there is a need?
the problem is attached.
thanks a lot
Old 7th May 2011, 02:55 PM   #2
SY's Avatar
Since this is clearly a homework assignment, and you clearly wouldn't want to cheat by passing off others' answers as your own, let's just ask a few questions. First: Given the max input voltage and the max output voltage, what does the gain need to be?
“There are no greater liars in the world than quacks, except for their patients.” - Benjamin Franklin
Old 7th May 2011, 03:47 PM   #3
10dB
Old 7th May 2011, 03:48 PM   #4
Default Gain
26dB sry
Old 7th May 2011, 04:47 PM   #5
SY's Avatar
OK, what is it in plain old linear (not dB)?
Old 7th May 2011, 04:56 PM   #6
Default gain
Av=20 (linear)
Old 7th May 2011, 05:09 PM   #7
SY's Avatar
Good! Now what does the resistor ratio have to be for a gain of 20?
Old 7th May 2011, 05:12 PM   #8
If we decide to put R2 = 2k , then Rf would be 38k.. we'll use 36k for a standard value which will give a gain of 19 which is quite close.. what do you think?
Old 7th May 2011, 05:22 PM   #9
Mooly's Avatar
Have you thought about the input to the opamp, DC conditions etc ?
A simulation free zone. Design it, build it, test it.
Old 7th May 2011, 05:25 PM   #10
Yes first I thought of creating a voltage divider (two 47K) from +12V vcc to -12V vcc for the input to swing on 0v and have plenty of headroom..
Anything obviously wrong with my mic pre amp ? nigelwright7557 Tubes / Valves 16 7th July 2008 09:43 PM
Upgrading an op amp in mic pre?? synap2012 Chip Amps 3 7th May 2008 02:26 PM
need critique, Mic pre amp impsick Solid State 16 25th May 2007 12:56 AM
What to use as a mic pre-amp? Gretsch6136 Analog Line Level 1 30th November 2006 09:17 PM
mic pre amp help psychosteve Solid State 0 12th February 2006 09:15 PM
Page generated in 0.11381 seconds (70.14% PHP - 29.86% MySQL) with 11 queries
