sound of discrete opamps
Old 1st May 2011, 06:06 PM   #11
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
agreed! for this reason, a "good" op amp and a "hot" i.e. high bias current like AD811 for example) buffer (low or unity gain) is hard to beat.
mlloyd1
Originally Posted by AndrewT View Post
and remember to design around the few uA of output stage bias.
Old 2nd May 2011, 09:43 PM   #12
robmil is offline robmil  United Kingdom
PHP Code:
I say this without the benefit of listening
I really have to take anything you say with a pinch of salt at this stage as I asked for 'has anyone had any listening experience'. Most folks here have their own ideas about the 'whys and nots' of IC vs discrete but this is about - have you.
Old 2nd May 2011, 10:39 PM   #13
fotios is offline fotios  Greece
fotios's Avatar
Default @ robmil
Yes, you are right. I think that i was not so clear by what i said. And yes, i have big listening experience with ICs working for many years with any professional audio mixing and sound processing device.
Where i say "discrete are unsurpassed from LOW up to MID frequencies" i mean:
Sound of discrete in Mids and Highs is "sweet" without colorations and screaming compared to ICs.
In Lows is extremely tight and "warm". You feel like you stay on a bandstand, between the bass amplifier and the drum kit.
Best Regards FOTIS ANAGNOSTOU
Old 3rd May 2011, 12:48 AM   #14
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
Originally Posted by Arty View Post
i simply do not see a real advantage of discrete opamps vs chips.
possibly can improve figures, but i allways had doubts about how usefull is it anyways.
I could be very wrong, but for example 0.001% thd or 0.00001 % thd makes no difference for me.
Then i check on valve amps and find rather high thd, reason to love a valve amp is its unique distorsion.
sounds a bit.. like split personality.
sure better to have and not need than need but not have, i agree with that, but is it realy worth it?
i dunno..
as a DIY project, creating Your own discrete opamp on the otherhand sounds more than nice
I find one particularly significant advantage that discrete op-amps offer over monolithic op-amps. Discrete implementations enable one to control the open-loop gain and distortion, and thereby, control the amount of negative feedback which gets ultimately employed. I, like many others, find low feedback circuits to in general sound superior to high feedback circuits. As you suggest, this is not really a question of objective distortion performance, it's a question of subjective listening performance. On strictly objective terms, it's none too easy to best the closed-loop performance of today's monolithic devices.
Old 3rd May 2011, 02:03 PM   #15
wakibaki is offline wakibaki  United Kingdom
Banned
Originally Posted by robmil View Post
[PHP]I really have to take anything you say with a pinch of salt at this stage as I asked for 'has anyone had any listening experience'.
I see you've found it impossible to ignore though. I'm just making my position clear, I could just as easily have left that particular piece of information out. I know you asked for listening impressions, but the logic of what I have said applies equally to listening, you are unlikely to encounter a big difference in sound unless one of the amplifiers performs particularly badly.
I get the impression that you're more interested in pursuing your pastime than in listening to any inconvenient truths.
w
Old 7th May 2011, 07:46 PM   #16
Dave S is offline Dave S  United Kingdom
I also use a JE-990 type circuit and find it sounds excellent. I have not found any IC or combination of ICs (e.g Jung's nested f/b scheme) that sounds quite as good.
One thing I did find with the JE-990 topology is that I'm not too happy wih the sound of the LM394. The SSM equivalent or a pair or 2SK170s sounds better, even a pair of 2Nxxxx sounds fine. Of course the JFETs will affect the loop gain somewhat.
My preferred option is: JFETs on the input (no input cap), no dc servo and a decent output cap.
I would like to try the Kaneda topology as some point to see if this is better than the JE-990. Anyone compared the 2?
Old 12th May 2011, 05:07 AM   #17
Bonsai is offline Bonsai  Europe
It is extremely easy to run an op-amp output stage in class A - just load the output to one of the rails with a resistor or a current source. Keep in mind that when driving a typical 10k output load to 10VRMS, most 'audio grade' op-amps will still be in class A, and at the more normal 1-2VRMS, they will be solidly in class A even without any output pre-load to force them into class A.
I have built many circuits, both discrete and with op-amps. While discrete designs have their place, I think op-amps offer some outstanding benefits. If one can see past the ant-feedback b.s. that seems regretably to permeate our hobby, I think on a double blind shoot out (yes, DB is the only scientific way to ***** equipement subjectively), I'd put my money on a good op-amp.
If you are looking for something that changes the sound of the source material, then of course that is a differentr matter - here indeed you may end up preffering a discrete or tube design.
Some specialst applications will demand a discrete approach - e.g. MC head amp or a dynamic mic pre-amp (but THAT corp have that covered with an IC as well now), and it could be argued (though its really open to debate) they may offer some performance benefits on MM inputs.
For transparency, accuracy, speed, linearity, its op-amps that win every time.
Old 12th May 2011, 05:53 AM   #18
CraigBuckingham is offline CraigBuckingham
IC op-amps. Heard many. Tried most everything you can do to improve the sound. O/P stage biasing works well even on reasonably biased IC op-amps. Use to use about 10mA and sometimes up to 20mA.
There is something else you can do that I never see mentioned on this forum, or anywhere else for that matter, that makes a significant inprovement. Maybe more than the O/P biasing. It has to do with common mode distortion - and I am not going to say anything more than that.
Designed a couple of discrete op-amps. Stopped using op-amps after that for serious audio reproduction. It is pretty easy to beat the best op-amps, even with all their tweaks, with a discrete op-amp. But hey why stay with closed loop when you have the option of open loop with a discrete design. Can't do that with an op-amp.
Then there is the question of thermionic vacuum tubes. Those things have no equal in the discrete world let alone IC op-amp world when applied in the right manner and in the right places. But the problem is dwindling supply of those parts unfortunately.
IC op-amps have a nasty gritty distortion that once you have heard and identified you don't want to go back to. The buggers can even be heard in the audio path when used for DC servos. I found a way around that too but that information is for sale only.
One of the other guys I did research with would probably give it away for free if you asked the right way. But hey some people prefer their egos boosted for their hard work and research rather than their back pockets.
Anyway, that's my findings.
Old 12th May 2011, 06:26 AM   #19
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Useful observations, thanks. I've been wondering for a while if sound quality is mainly to do with the input stage's immunity to RF. As I recall the JE-990 has a unique feature - inductors to degenerate the input pair. Have you any experience with trying different inductors (values, styles) in the Re circuit? Does replacing just those two inductors with resistors make a difference to the sound?
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 12th May 2011, 11:20 AM   #20
"IC op-amps have a nasty gritty distortion that once you have heard and identified you don't want to go back to. The buggers can even be heard in the audio path when used for DC servos. I found a way around that too but that information is for sale only."
LOL - do you really want us to believe that?
sound of discrete opampsHide this!Advertise here!
Are Discrete components better than Opamps ? jsa_ind The Lounge 53 6th September 2016 03:35 PM
low noise discrete opamps robmil Solid State 0 7th May 2010 08:24 AM
discrete vs. IC opamps? has anyone tried the pass labs design? dorkus Pass Labs 22 28th June 2001 02:02 AM
