| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Hi
I need a line amp with a gain of around X10 to drive 10meter cables and 10K input impedance power amps. I would prefer an all descrete design avoiding op amps. Maybe even an open loop design. Any sugestions? Thanks. |
#2 |
I have a Erno Borbely SE headphone/Line amp ( assembled but only tested ) - capable of even driving 50 meter cable - extremely low impedance available - I had listed about a month back
let me know if you are interested kannan |
#3 |
Electrons are yellow and more is better!
You could use a diamond buffer which I give away for free.
http://www.diyaudio.com/forums/blogs...e-pcbs-me.html
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
Discrete, transistor amplifier x10 and driving 10k.
And no global feedback. It happens I have just such a circuit. It uses 3 small signal transistors. Like 550C or 2SC2240 or 2SC1815. Two stages with volt amplification is followed by 1 transistor as buffer. Circuit is tuned for lowest possible THD distortion. Into 10kOhm: At 1 Volt RMS out THD only 0.011% At 2 Volt RMS out THD is 0.046% This is, I think, all below hearing limit 0.05-1.00% Power supply is 15V. Preferably one usual 3pin regulator. Enjoy
lineup |
#5 |
Hi Thanks for your very quick replies and sugestions.
Peranders your diamond buffer looks like a very nice, but as its surface mount i think i will pass on your offer, my eyes are not good, i struggle a bit even with conventional components. It does look a great design though. Lineup, is there a way to loose the coupling cap between the 2 gain stages? |
#6 | |
G˛ |
#7 |
you can find what current it takes to charge up the capacitance of the cable. The faster the charge rate, the higher the current. The highest sensible cable capacitance current is usually to assume maximum signal level @ 20kHz into the cable and any subsequent RF filter.
regards Andrew T. |
| Very long line level cables, what to use? | ChrisA | Analog Line Level | 16 | 7th May 2010 11:29 AM |
| I've built some amps, need suggestions for a DIY preamp or line stage | jduffy | Tubes / Valves | 13 | 3rd January 2007 11:58 AM |
| ssabripo's DIY Interconnect cables: $200 cables for 1/10 th the cost! | ssabripo | Everything Else | 3 | 26th October 2006 02:33 PM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 01:19 AM |
| cables for diy amps, preamps, and speaker cables ... | paulspencer | Solid State | 5 | 3rd August 2004 07:14 AM |
| Page generated in 0.09031 seconds (77.51% PHP - 22.49% MySQL) with 11 queries |
