Go Back   Home > Forums > Source & Line > Analog Line Level
Old 15th April 2011, 07:28 AM   #1
DionG is offline DionG  Australia
Default Linkwitz-Riley low pass, strange distortion?
Hi all, so im trying to build the low pass filter part of the following design of Linkwitz-Riley Electronic Crossover .
so far I have built the bit outlined in red so i decided to test it on an oscilloscope with a wave generator and i seam to get generally the right shape but its got lots and lots of high frequency stuff in there. again the input is a clean 85hz. the output looks like below
edit: shocking drawing i know
so yea, any ideas what the hell is going wrong? or is it something simple i just don't know?
its using 1% metal film resistors and 1% metalized film polypropylene film capacitors and NE5532.
also, its using 33nf and 40Kohm on the low pass section to cross at 85Hz (which it does respond to when i change the frequency)
any help is great
Dion
Old 15th April 2011, 07:39 AM   #2
infinia is offline infinia  United States
infinia's Avatar
and the input looks clean? can you trigger on the noise freq? could be a lot of things, op-amp unity gain stability, oscillating not enough PS bypassing, grounding on the probes, or SMPS common mode noise. is it an analog scope with a high BW? measure yer ground and supplies.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 15th April 2011, 09:45 AM   #3
...yes haha
umm input is crystal clean.
as for the rest i have no idea what any of it means.
if it helps, i took an output right after the input buffer and its the same.
could if have anything to do with ground loops or anything. also its power by a lap power supply (unfiltered at them moment). noisy? and the ground of it is connected to the ground of the input and output. are they supposed to be connected? when they weren't there seamed to be some other problem. the occiliscope was has a wave passing through it doing other weird stuff
im just lost haha
Old 15th April 2011, 10:02 AM   #4
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Originally Posted by DionG View Post
...yes haha
im just lost haha
Probably switching noise from the laptop supply through the grounding.
This is not a circuit problem but a measurement/grounding issue.
You really need a good linear supply.
Try a couple of 9V batteries, I bet it's clean then.
Also try to move the ground point from the ground lead from the supply to different points in the circuit. And ohh, yes: put the scope probe ground clip to the same point as the supply ground lead!
jan didden
/Another new issue: Linear Audio Volume 3!
Old 15th April 2011, 04:09 PM   #5
so to get this right, use some batteries or regulated voltage supply and connect the ground on the supply to the ground on the scope but don't or do connect it to the ground on the input wave??
thanks, then i'll test it and give results
Dion
Old 17th April 2011, 06:36 AM   #6
WIN!!!
so i filtered the lab power supply with some 33nf caps that i was using for the crossover and it turned the output signal clean.
thanks for the idea Jan
there is however a noticeable distortion at the peaks of high frequency waves ( maybe the power just isnt regulated enough. As in that's what im assuming until i test it with some actual power regulator chips).
Also, i had all the grounds connected together (including the input, power supply and output ground). is that the best thing to do?
thanks as always
Dion
Old 17th April 2011, 07:50 AM   #7
janneman's Avatar
WIN!!!
thanks as always
Dion
So it seems the opams were oscillating due to poor supply decoupling. It is good practise to have a local decoupling cap on each supply line physically close to each opamp, like a pair of 0.1uF. Don't use high-Q foil caps here; you want some losses to quench any oscillation tendency. Ceramics are ideal here, or some 1-10uF electrolytics.
Edit: that distortion on hf waves, what freq and level are you talking about?
jan didden
Old 17th April 2011, 12:27 PM   #8
Jan,
yea i'll put some electrolytics in there from now on to help that. and it will be from an actual regulated supply and not just lab power supply lol.
umm not sure of an frequency, i can find out if you like although personally i thinks is just the crap supply as i was only using 33nf polypropylene ones, and therefore couldn't stop the lower frequency stuff. it was putting out about +- a volt on the test.
cheers
Dion
Old 18th April 2011, 02:01 AM   #9
Hi, to anyone who would like to help, i need to get the +- 15v for the preamp but i only have a +-34v DC at the moment. as the LM7815/7915 can take +-35v i was just going to put it straight into the regulators (with smoothing caps on both sides of course).
I was just wondering if you think that will be ohk or whether i should do something else? it wont giving much power as it only goes into the opamps and into the LM3886 amp board.
cheers
Dion
Old 18th April 2011, 05:46 AM   #10
infinia's Avatar
You could use series R in front of each Vreg to take off some voltage and heat.
Maybe in your case, R could drop about 15V. R~ 15V/n*Iq , where n = # op amps , Iq = quies. current of each op amp. (note add a couple of mA to the total for the regulator part as well). Calculate the power dissipated for the R and the regulator, making sure each part can stand the heat with their power ratings.
add a shunt cap (10-100 uF) after the new series R for a noise filter and to keep the input of the Vreg stable.
Linkwitz-Riley Crossover questions MBrej Solid State 2 15th January 2009 12:19 PM
A Challenge to Linkwitz-Riley ? jackinnj Multi-Way 17 14th March 2006 11:50 PM
Linkwitz Riley Filter Implementation Roysyboy Subwoofers 1 19th September 2005 03:40 AM
Linkwitz-Riley Cross over question rs1026 Chip Amps 2 27th August 2004 09:15 PM
linkwitz-riley crossover arthur Solid State 0 28th April 2003 10:26 AM
Page generated in 0.12830 seconds (72.71% PHP - 27.29% MySQL) with 11 queries
