do I need vintage preamp?
Old 14th April 2011, 07:55 PM   #1
gychang is offline gychang  United States
Default do I need vintage preamp?
I have a t-amp (power amp) that I like to use but has only one RCA input. I want to use it for my PC (music files) and my desktop CD player and want to add volume/input selector.
I can see 3 major possibilities.
1. is there a "radioshack" like product, with volume/RCA selector for cheap?
2. is there a DIY product (I can solder but can't read schematics etc)
3. Possibiy a vintage preamp on craiglist.
thanks in advance, will appreciate input.
gychang
Old 14th April 2011, 08:36 PM   #2
amt is offline amt  United States
For $50 you can build a nice passive attenuator with input selection. An Alps pot, three sets of RCAs and a toggle switch should sound much better than a beat up old preamp and be far more compact.
amt
Old 14th April 2011, 08:44 PM   #3
john curl is offline john curl  United States
john curl's Avatar
Passive is good, and have a friend help you wire one up.
"Condemnation without Examination is Prejudice"
Old 14th April 2011, 08:52 PM   #4
eclectic2k is offline eclectic2k  United States
eclectic2k's Avatar
Originally Posted by amt View Post
For $50 you can build a nice passive attenuator with input selection. An Alps pot, three sets of RCAs and a toggle switch [...]
you could also consider this thread (if you want to go fancy and maybe have remote control) - note that his is also passive unless you decide to build an active buffer...
otherwise, amt's correct. for very little money and just a few parts you can build a decent selector and passive volume.
A "vintage" preamp is also OK if it's more to your taste, or you decide you want more features. But where's the fun in that ;-)
Old 14th April 2011, 09:18 PM   #5
amt
any chance on the website that has the correct parts for the items u mentioned?, I have several RCAs, but no toggle switch, and do have a Alps pot laying around.
gychang
Old 14th April 2011, 10:28 PM   #6
badman is offline badman  United States
badman's Avatar
gychang
PM me and swing by the badshack, I can help you get this together. I'm in Tustin. Saturday's probably good.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 14th April 2011, 11:15 PM   #7
Heres a quick wiring diagram. The best toggle around is the Tocos sold by Percy Audio and the worst are the ones sold at Ratshack.
Keep the wiring as short as possible and make sure the RCAs are isolated from the chassis (if its metal).
amt
Old 15th April 2011, 12:26 AM   #8
amt
thanks so much!, even I can follow this diagram, will order the DPDT (on/on, NOT on/off/on, right?) as u suggested. It will be in a small wooden case, the grounds on the RCA has to be soldered together? Thanks, again, I will do this. gychang
Old 26th April 2011, 01:40 AM   #9
JoeDJ is offline JoeDJ  United States
JoeDJ's Avatar
What if I wanted to make a 4 input selector without a volume control?
Old 26th April 2011, 02:51 AM   #10
amt
It works!!, I managed to follow your diagram, and soldered the RShack cheapie and Alps pot and it is dead silent in the background and music is glorious!!, thanks. Now I want to try 3RCA input, can u recommend a part?, seems like RShack and Partsexpress don't carry and I would like some recommendation, I will try some good ones this time for hopefully for my reference build. My soldering skills have improved and I am starting to get hang of this.
Thanks again amt. I will put up my pictures may be tomorrow night, just pure music without any hum, it is dead silent during music pause...
gychang
do I need vintage preamp?Hide this!Advertise here!
Vintage Audire Diffet 2 preamp help releone71 Analog Line Level 3 26th December 2011 03:23 PM
Vintage Preamp Tubes iriegnome Swap Meet 0 25th January 2010 03:26 PM
crate vintage club 50 2x12 keeps blowing preamp tubes etwnpnks Instruments and Amps 1 13th January 2010 10:22 PM
Vintage Infinity FET Preamp john65b Solid State 5 16th December 2009 04:08 PM
Total newbie post - trying to replace ext. PS on vintage Mark Levinson ML-1 preamp yamezxx Power Supplies 3 26th August 2009 04:29 PM
Copyright ©1999-2017 diyAudio
