microphone echo & delay fx circuit
Old 5th August 2011, 09:21 AM   #21
bernhix is offline bernhix  Philippines
Can I have a chance to get hold the schematic of the said echo and reverb effect? I will use it in adding echo for my Mics.
My e-add is d_stantman@yahoo.com.ph
Old 5th August 2011, 02:17 PM   #22
anshuman2512 is offline anshuman2512
I am in middle of making the delay using PT2399, after checking the performance will post the schematic if anybody would like to make it....
Anshuman
Old 8th August 2011, 10:25 AM   #23
Thanks, will wait till it's available.
Old 7th September 2011, 07:37 AM   #24
sudhir kumar is offline sudhir kumar  India
Anshuman
What is progress of your project and performance?
Old 7th September 2011, 07:47 AM   #25
i recently found a kit from junk.Perhaps it is a microphone echo circuit.It has two 4558 and one pt2399.I will test it and post the results.
Old 12th September 2011, 05:12 AM   #26
I have tested the PT2399 kit.It is working very good.I have added DELAY,REPEAT pots from the datasheet.I can say definetly that it is worth making when compared to its price and easy circuit.Surely it is not hi-fi but perfectly fit for home use eg.karaoke etc.
One thing more i want to add a DRY-WET pot to it,Please tell me the procedure.
thanks.
Old 15th September 2011, 05:40 AM   #27
I have again tested above referred kit.Result is very very good for voice applications when using the delay and repeat timing very less(most usable).i have added presets for adjusting delay time & repeat.Photos are attached.If any body had made this circuit i want to know about their result.
Old 15th September 2011, 11:32 AM   #28
I want to add a dry/wet pot in this kit.any help please??????????
Old 17th September 2011, 05:49 PM   #29
Default PT2399 echo/reverb schematic
I have done it 20 days ago, sorry couldn't post the schematic and the kit pic... it sounds awesome, i made it for my electric guitar, you can give it a try and let me know how the performance is, PCB designing and etching is also done by me.... attaching the schematic (2 parts) and the snaps of the completed kit (taken from digi cam).... please let me know if you have any question....
Old 17th September 2011, 06:08 PM   #30
AnshumanAttachment 240439
Attachment 240440
Attachment 240441
Attachment 240442
PT2399 is available in bangalore ... i am building another one PT2399 along with compander NE571 which i used for my delay (MN3005)...
If someone else have good reverb/chorus schematic using MN3011 please post the same, i built the DOD FX-45, but not happy with the performance
microphone echo & delay fx circuitHide this!Advertise here!
echo, reverb using bucket brigade delay lines from panasonic Workhorse Solid State 20 6th April 2011 12:37 AM
cassette tape echo / delay thegunshyboy Instruments and Amps 10 23rd November 2006 11:36 PM
PT2399 Echo / Delay Audio chip -_nando-_ Digital Source 1 28th August 2006 02:53 AM
Delay - echo through BL and FL horns jamikl Multi-Way 4 3rd April 2006 06:52 AM
Need echo microphone darkm4n Digital Source 0 2nd October 2004 09:35 PM
Copyright ©1999-2017 diyAudio
