Cello Audio Palette - Page 7 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 19th April 2013, 04:41 PM   #61
Default Review Hi-Fi News & Record Review, Nov 1985
Here a nice review!
Unfortunately there are no measurements in this review...
File Type: pdf cello-audio-palette-review-hifi-news-1985.pdf (735.9 KB, 150 views)
Old 20th April 2013, 03:49 PM   #62
Nrik is offline Nrik  Denmark
measurements on Palette Preamplifier - the opamp version.
The frequency manipulation is what I used for calculating the filters.
Henrik
Old 20th April 2013, 04:01 PM   #63
More reading. (991KB PDF download)
From page 8 and on some sound engineers express their joy with among other cello equipment also the Audio Palette.
Henrik
Old 18th May 2013, 06:44 PM   #64
Here is how it looks these days
Henrik
Old 19th May 2013, 01:23 PM   #65
Wow, nice engravings!
Old 19th May 2013, 05:23 PM   #66
The text is made with letraset transfers, not engraved.
Henrik
Old 19th May 2013, 06:43 PM   #67
That's one of the reasons the original AP was so expensive. Levinson used real engravings and paid incredible attention to details...
Old 21st November 2013, 04:44 AM   #68
Nrik,
I tried using both Rod Elliott's MFB-filter program and the spreadsheet from Project 136 to calculate the filters. Both of these tools give negative resistor values for R2 when Q=.7 and the gains & center frequencies needed for the Palette controls are input. Did you end up using non-equal C MFB filters instead? There are solutions with non-equal C filters.
- Eric
Old 22nd November 2013, 06:19 PM   #69
ticktock's Avatar
Beautifully made, Nrik !!
thanks
Blaue Leuchtdioden machen blöd. (hb)
sent from NSA monitored device
Old 3rd January 2014, 08:57 PM   #70
...hey guys, sorry for not replying in my own thread for 1˝ month.
Thankyou Ticktock
Eric Weitzman: You should read Rod Elliots Expandable Graphic Equaliser instead.
I will check up what values I used exactly at some point, but what you also should know, is that I put the gain in some separate opamps, and let the filters be filters.
Thinking back I even think I calculated each filter to be -6dB down and added that to the gain, because the filters had both high-pass and low-pass attacking the same frequency ( -3 +-3dB = -6dB)
Henrik
Cello-bodied stereo niccohel Instruments and Amps 2 11th May 2007 09:07 AM
Cello Palette voltage change? young_pup Solid State 3 27th September 2006 11:23 PM
Cello Amplifier Schematics moray james Solid State 5 12th April 2005 07:13 AM
cello theremin ouwerocker Instruments and Amps 5 31st December 2003 06:02 AM
Copyright ©1999-2017 diyAudio
