| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
I’ve searched and read a lot about this, but I’m struggling to find a definitive answer for my particular case. How does this sound for a grounding plan: The input selector only switches signal +ve, sends it to the stepped attenuator, then on to the output +ve. The left input grounds are bussed together, along with the left output ground. The right input grounds are bussed together, along with the right output ground. This keeps the left and right grounds and signals completely separate. Will this work, or do I need to connect these ground busses to the chassis (aluminium) somewhere to avoid RFI? Also, in this arrangement each signal ground is connected to the ground circuits of all the other pieces of equipment currently plugged in to the inputs. Will this be a nightmare for hum? I can’t see an alternative to this though, as I can’t have a separate ground for every RCA connector unless I double up on poles and switch the grounds as well as the +ve. Almost every design of passive pre I’ve seen doesn’t switch grounds though, only the +ve. Confused. Cheers, Leon |
#2 |
anything more than monoblock construction requires signal grounds and power grounds to be interconnected at some point.
Read Audio Component Grounding and Interconnection - diyAudio thoroughly and go back and pick out the important messages for your intended use. Only 58k views. There's a lot of Members that refuse to research.
regards Andrew T. |
#3 |
If a 'passive preamp' has a metal box then the box has to be grounded, otherwise it could increase pickup.
#4 |
A shield does not need to be grounded. Or am I wrong again?
regards Andrew T. |
#5 |
Inside a screen the potential is everywhere the same. A circuit completely inside the screen, with no external connections, will not be aware of any electric fields outside the screen. In this situation the screen does not need grounding.
If the circuit has an external connection (and most do) then it becomes sensitive to the difference between its ground and the screen potential. An ungrounded screen then becomes a probe, sensing the external field and passing it on to the internal circuit. As the screen is presumably larger than the circuit, it will pick up interference more effectively than the circuit would on its own because it has a larger capacitance to any external conductor. |
#6 |
Why/How does your explanation confirm that the screen (in this situation metal chassis) must be grounded?
regards Andrew T. |
#7 |
The circuit inside has external connections. In this case, another name for an ungrounded screen is a coupling capacitor!
#8 |
I still can't see why?
regards Andrew T. |
#9 |
#10 |
I happen to have it open since earlier this morning.
I will go and look again.
regards Andrew T. |
| Simple passive preamp. Neen some help in grounding. | FaTTy | Solid State | 32 | 20th July 2007 06:10 AM |
| Grounding in a Passive Line Stage | Zero Cool | Solid State | 7 | 12th March 2006 05:19 PM |
| Hypex HS200 plan, take out signal after preamp | awagner | Solid State | 1 | 2nd November 2004 08:23 AM |
| 5687 Preamp as I plan to build it. | G | Tubes / Valves | 33 | 23rd July 2004 04:06 PM |
| APOX passive volume grounding | tiroth | Solid State | 0 | 27th February 2004 05:53 PM |
| Page generated in 0.18928 seconds (48.85% PHP - 51.15% MySQL) with 11 queries |
