diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Analog Line Level (http://www.diyaudio.com/forums/analog-line-level/)
-   -   Hafler DH-101 Pre-Amp (http://www.diyaudio.com/forums/analog-line-level/185485-hafler-dh-101-pre-amp.html)
wally5 21st March 2011 12:10 PM
Hi, what can I replace C12 with thats available, its a 15pf 1000v Ceramic.
https://picasaweb.google.com/1133366...NG5_dbT2qrlTA#
BobEllis 21st March 2011 01:41 PM
S150K25SL0N63L6R Vishay/BC Components Ceramic Disc Capacitors if you can't find a local distributor.
Without the schematic it's hard to tell, but I'd suspect that you don't need the 1000V rating. You can probably use a 15 pf mica cap, usually available rated at least 500V
stratus46 21st March 2011 04:10 PM
Originally Posted by wally5 (http://www.diyaudio.com/forums/analog-line-level/185485-hafler-dh-101-pre-amp-post2511097.html#post2511097)
https://picasaweb.google.com/1133366...49348/Desktop#
The power supplies in this unit are +/- 18 Volts. Any 15pF cap you'll find should be fine. Personally, the Mica suggestion from Bob Ellis would be very good, a C0G would also be good. Polystyrene are excellent but some flux removers attack the styrene.
What happened to the original cap?
Nice work on the unit though I wouldn't use an OSHA cord on it - especially if any other unit has a 3 wire power cord as it's the surest way to ground loop issues. It looks like you are not using the 3rd wire as I don't seem to see any solder on the terminal in the photo. Is that right?
A worthy mod to it improves the phono preamp and adds a needed high level input is to remove the phono 1/2 low level input switching and make phono 2 a high level input - in my case for the CD player. I did that back in '83 when I got the first CD player.
G≤
wally5 22nd March 2011 03:50 AM
Thanks for your replies, I thought the idea was to get rid of ceramics in the signal path, will Silver Micas sound better.
I was stuck on voltage rating, didnít know I could use 500v Silver Micas, which you can get quite easily.
The earth on IEC socket is not being used, just a floating ground like it was from original. Like the idea about Phono switch.
bobrown14 23rd March 2011 01:22 AM
Originally Posted by wally5 (http://www.diyaudio.com/forums/analog-line-level/185485-hafler-dh-101-pre-amp-post2512113.html#post2512113)
I was stuck on voltage rating, didn’t know I could use 500v Silver Micas, which you can get quite easily.
+1 - I replace the ceramic caps with those LOW pF requirements with mica.. Probably your only upgrade path. I've been looking for a 68pF 500V for my pre-amp (HK -17) replacement and found mica to really be the only easily available part here in the states.
Oh and Hi to all, I think my first post here (analog line level section).
Bob
wally5 23rd March 2011 02:32 AM
Originally Posted by bobrown14 (http://www.diyaudio.com/forums/analog-line-level/185485-hafler-dh-101-pre-amp-post2513151.html#post2513151)
Bob
Hi, I get most of my parts from this company here in NZ.
Active Components ::
bobrown14 23rd March 2011 02:50 AM
Originally Posted by wally5 (http://www.diyaudio.com/forums/analog-line-level/185485-hafler-dh-101-pre-amp-post2513200.html#post2513200)
Ooohhhhh.....gotta thank you.
Bob
Jim W 23rd March 2011 04:01 AM
According to my schematic, C12 looks like it couples the preamp output to the inverting input of a differential pair, providing high frequency rolloff. I wouldn't guess that it would affect the sound quality greatly, and that any cap with good high frequency response and a reasonable tolerance would be fine.
Jim
Resources saved on this page: MySQL 18.75%
Copyright ©1999-2017 diyAudio
