connect IR receiver
connect IR receiver
Old 21st March 2011, 02:08 PM   #31
R.I.P.
Got it working.
Yes, it's a module rather than just a opto transistor.
It starts working with 3.5Vdc and in circuit has 5V54 on pin3, pin2 = 0V0
The 10k pull up on pin1 shows a few tenths fewer volts.
Clear codings on pin1 when buttons pressed.
Damaged a Control board when I connected power to the wrong pair of pins, very big OOPs.
Second board works, select inputs and adjusts volume. But the vol pot must be very sticky in the mid range, it slows down to almost a standstill in both directions.
Checked noise on pins 1 & 2
Pin 2 fed from an RC filter, 47r and 47uF, shows approx 7mVpp sharp pulses and 1.1mVpp wideband noise.
Connected 100nF ceramic across pin3 & pin2, wideband noise reduced to 1mVpp and all pulse noise buried in the wideband.
Moved the decoupling cap to the output of the RC filter on the control board. Absolutely no effect. Proves where decoupling must be located !
This decoupling may have a very slight effect (difficult to read if any change) on the wideband noise of ~0.5mVpp at pin1. The digital output (~3.8Vpp) of pin1 completely swamps the noise which is ~-77dB under the digital signal.
Thanks for all the help.
regards Andrew T.
Old 21st March 2011, 03:02 PM   #32
Mooly's Avatar
connect IR receiver
Hi Andrew, pleased to hear it's all working.
Decoupling... this is what I keep saying regarding ultra low noise regs etc. Great, but the effect is totally lost when connected via some leads, PCB etc to a "noisy" DAC or whatever.
I wouldn't worry to much over noise etc on the IR receiver supply, certainly not at the levels you mention... but it's nice to get it right
Old 21st March 2011, 06:09 PM   #33
fotios is offline fotios  Greece
fotios's Avatar
Hi Andrew
Glad to hear that you resolved the problem. As for the vol pot unstable rotation speed, probably it is a matter of wrong MCU code "delays".
Best Regards FOTIS ANAGNOSTOU
connect IR receiverHide this!Advertise here!
20 channel IR transmitter/receiver frd_usman Everything Else 3 1st July 2009 06:36 AM
IR Receiver - 3.5mm jack for Home theater Processor JRace Parts 5 30th March 2009 02:57 AM
IR receiver for CD transport Remote Manolo47 Digital Source 0 4th January 2009 11:44 PM
IR receiver parts cd304 wanted Onnosr Vendor's Bazaar 0 4th April 2008 02:08 PM
Kit for sale: 10 Channel IR Remote Control Receiver jamesjung21 Swap Meet 0 25th October 2007 08:30 AM
