Go Back   Home > Forums > Source & Line > Analog Line Level
Old 10th March 2011, 02:52 AM   #21
schubert's Avatar
Originally Posted by VictoriaGuy View Post
You need a decent ground reference for troubleshooting....either a proper earth ground at your workbench (direct connection to good ground rod) or (better) a connection to the ground of your AC house supply.
'Cheater' plugs assume that the wall box is grounded and connect to the faceplate screw...so that is one place to look.
With 'modern' plumbing, it's not a sure thing that you can get an earth ground from a plumbing connection - too many ways that you can get a plastic 'break' in the line, IMO.
I could use the "third wire" connection in the outlet above my "workbench" (which much to my wife's chagrin doubles as the kitchen counter), for it's a new outlet and the ground is connected to a rod buried in the earth right below the circuit breaker box in the garage.
Can I directly measure 220V AC with a oscilloscope? Sunsun22 Equipment & Tools 17 5th October 2010 09:01 PM
Directly connected transformerless amps Steve Eddy Everything Else 9 6th August 2007 04:56 PM
Why is GND of scope channels connected to case? luka The Lounge 7 18th February 2007 07:35 AM
connecting input directly to ucd, no input buffer mazurek Class D 20 19th July 2006 03:32 PM
What is the metal case of a quartz connected to? Bricolo Parts 4 24th April 2004 06:45 PM
Copyright ©1999-2013 diyAudio
