Volume Equilizer
Volume Equilizer
Old 6th March 2011, 04:53 PM   #31
Mooly's Avatar
Volume Equilizer
Originally Posted by Michael Bean View Post
For many of my own designs, I've used indvidual input attenuators right after each input jack. That way you can adjust the average loudness level to be more uniform from every source, and you can also correct any channel imbalance the some devices have at thier outputs.
But keep in mind, there is no set standard with regard to loudness levels in recorded material, so volume adjustments are almost inevitable.
Just my $.02 worth.
Exactly
Old 6th March 2011, 05:21 PM   #32
gkhnoisgtht is offline gkhnoisgtht
so the idea of having an automatic volume adjustment isn't really feasible it seems?
thank you everyone who has offered idea's and suggestions. This has really been an enlightening weekend. I will have to look over some of your projects and see if I can figure out any alternate way to accomplish my goal.
Old 6th March 2011, 05:25 PM   #33
o before I forget:
if you have a signal going into a device, then switch to another device (that is significantly louder than the previous) is there a way to automatically attenuate the second signal so that your not blasted out of the water by the volume difference, or blow out speakers?
would that be an easier goal than my other idea?
Old 6th March 2011, 06:15 PM   #34
purplepeople is offline purplepeople  Canada
purplepeople's Avatar
Originally Posted by gkhnoisgtht View Post
o before I forget:
When I switch from cable box, I lower the volume before playing a DVD, then turn it back up. Same with playing something from my laptop, or even when switching from DVD to CD in the same changer carousel.
:)ensen.
Those who claim to be making history are often the same ones repeating it.
Old 6th March 2011, 06:15 PM   #35
Mooly's Avatar
Volume Equilizer
o before I forget:
This is what we are trying to say
If this "device" is an amplifier then all you do is arrange for each input e.g. CD, DVD, TAPE, TUNER ETC ETC to have it's own resistor (just one for each channel and each input) that gives equal volume from each source.
Old 6th March 2011, 11:28 PM   #36
i understand now. Thanks for the help.
Old 7th March 2011, 04:05 AM   #37
stratus46 is offline stratus46  United States
o before I forget:
If you implement Mooly's idea of presetting the audio levels to a nominal value you really shouldn't have problems unless you have some really bizarre recordings. I have some early Deutsche Grammophon CDs that had a ridiculous amount of headroom meaning they were unusually low levels compared to the average but they were the exception.
You could build a microcontroller switching system that muted the audio and then ramped it back up after the switch selection but you'd still have do deal with the change though you'd have a few seconds to do it. The rest of us just know to back off the volume before switching sources. A lot cheaper that way.
G≤
Volume EquilizerHide this!Advertise here!
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Replacing broken volume control with digital volume control Gunawan W Solid State 19 15th December 2010 10:46 AM
how to hook up equilizer? SharpyWarpy Everything Else 4 17th July 2007 01:01 AM
volume fabpri Chip Amps 6 15th February 2004 05:15 AM
volume... rask Multi-Way 2 29th April 2002 05:32 PM
