Arduino controled PGA2310 Preamp
Old 3rd August 2016, 05:37 PM   #21
Idiosyncrasy is offline Idiosyncrasy  Netherlands
Megahurtz
Originally Posted by maxw View Post
I don't think I ever complete an Arduino PGA2310 project.
I made another preamp, details are here:
Building a complete Preamp with an Arduino, remote, volume and input control
And you can find the code here:
https://github.com/FutureSharks/preamp-v1
Or a passive one here:
Passive Preamp: Arduino based, remote control, Relay R2R, input selection
https://github.com/FutureSharks/preamp-passive
Maybe you can find some useful code in there
Hey Max, that looks really nice (your previous preamp too btw ). What's the Johnson noise like though with that many large resistors (in the passive preamp)?
Would you choose the DAC8812 again today or do you feel there are better alternatives available?
Old 3rd August 2016, 05:48 PM   #22
isakeliyahu is offline isakeliyahu  Israel
Hi max
Thank you very much!
I actully mange to work with arduino and the pga3210 flawlessly!
No noise, no jams, no nothing, just perfect!
I used the recommended schemetics in the datasheet, no more no less.
Old 3rd August 2016, 08:09 PM   #23
maxw is offline maxw  United Kingdom
maxw's Avatar
I'm not sure. Can you hear "Johnson noise"? Or do you measure it?
I think it's still the best. Unless you can find another 16bit R2R that is SPI controlled. I actually just made a new design using this IC but it's really just a slightly different layout and without the isolation IC (photo attached).
Originally Posted by isakeliyahu View Post
Hi max
Excellent. I always had some background noise with my PGA2310s.
Old 3rd August 2016, 10:19 PM   #24
Megahurtz
AFAIK it'd be white noise if you'd hear it. If not, well, then it's not too large.
Why change a winning formula, eh? Really dig the original approach you took with this design, using the signal as the reference voltage for the DAC.
Old 3rd August 2016, 11:28 PM   #25
Hi max.
Ok, now i can a small problem, its not so noticeable, only when standing really close to the monitor i can hear the steps going up and down.
Im using a regular pot.
Do you by any chance have a solution for that?
Old 4th August 2016, 02:19 PM   #26
maxw's Avatar
I think there is always some noise when using a passive attenuator, including a pot.
Thanks but I just copied some other implementations, chose some parts and designed some PCBs. My actual electrical engineering knowledge is very limited
Hi max.
I don't understand. Are you using a pot? Or PGA2310?
Old 4th August 2016, 02:22 PM   #27
Im using a pot to control 8 X PGA2310 via arduino.
Now only one is conected for testing
Old 6th August 2016, 09:55 AM   #28
Megahurtz
Im using a pot to control 8 X PGA2310 via arduino. Now only one is conected for testing
Have you got zero crossing enabled, i.e., pulled ZCEN (pin 1) high?
Old 6th August 2016, 10:39 AM   #29
Yes i am.
Do you think i should connect it via 10k resistor to 5V or connect it direct is ok?
I must remind you im using regular 100k anlog pot, so when i turn it all the way its going up very fast unlike the encoder that i need to turn for ever to have max Volume.
Old 6th August 2016, 03:25 PM   #30
Megahurtz
Yes i am.
For the very similar PGA2320 I connected it through a 10K resistor. It works fine, but I don't recall reading about it in the datasheet. I've seen a few other designs that also used a resistor to connect ZCEN to the 5V rail.
Hmm, I'm controlling the IC using an Arduino that reads an encoder. How exactly would you use an analog pot here? Do you have it wired to an analog input on your microcontroller or something like that? And, if that's what you're doing, whether it goes fast or slow simply depends on how you map your input to whatever volume you send to the PGA IC, doesn't it?
Arduino controled PGA2310 PreampHide this!Advertise here!
My Preamp Project: Arduino, I2C, relay selector+attenuator, tube stage maxw Analog Line Level 63 31st March 2015 06:33 PM
Arduino controled HIFI Preamp ialpha Parts 22 9th November 2014 10:35 PM
Sylonex and Arduino preamp oenboek Analog Line Level 17 12th March 2011 12:50 AM
PGA2310 based preamp finished bostjancek Chip Amps 24 19th July 2010 08:59 PM
Arduino based Input Selector for preamp _atari_ Analog Line Level 5 30th June 2010 02:42 PM
