Yaqin SD-CD3 Tube Buffer - upgrading caps
Old 23rd June 2013, 09:17 PM   #121
pixelphoto is offline pixelphoto  United States
Default Grant Fidelity MK2 tube buffer caps mod
Hello zcables,
I saw your post and the mod you did to your Grant Fidelity tube buffer. I also have a Grant Fidelity MK2 and thought why not mod mine. And thanks to your post and especially the photo I did just that with great results. I used Clarity SA Caps. As soon as I reconnected the buffer to my system, Sony PS1 (1001) modded using Dog Breaths mod suggestions and NAD 326BEE amp the first thing I noticed was the clarity of the sound (really, no pun intended). The buffer now has over 100 hours on the new caps and is sounding sweet.
I will repeat what you said about removing and installing the caps. No need to access the bottom of the board. Desolder the caps from the top side of the board. Cut the new cap leads just long enough to pass through to the bottom of the board.
Happy listening,
Marvin
Old 24th June 2013, 04:25 AM   #122
Gost22 is offline Gost22  Bolivia
Banned
Hi pixelphoto!
Give to see changes in the modified schematic that you've done in a positive way.
thanks!
Old 29th September 2013, 01:30 AM   #123
acylonmiklos is offline acylonmiklos
Default This is my mod
I can't really say how or if it sounds better, but it was only $38 bucks shipped and I feel happy just thinking about it
Claritycaps from Madisound
Input
2x ESA 2.2uf
Output
4x SA .47uf
I used a 40w solder iron, was too big but my 15w was too small.
I watched YouTube videos to learn how to solder.
Old 29th September 2013, 01:41 AM   #124
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Originally Posted by Uunderhill View Post
There seems to be a lot of negativity here from some recent posts.
Yes - the schematic is dissapointing - especially, after looking at the Aikido and White Cathode followers.
However, tinkering with the Yaqin CD3 does provide inspiration to build a tube preamp.
Even a tube pre with a transformer coupled output.
The CD3 was $159 + $15 shipping.
So I'm not sure about the comment about fancy case and sold for a high price.
Clearly in some impedance situations, the Yaqin CD3 can provide impedance improvement.
Zin > 1 Meg
Zout ~ 180 ohms
Coupling caps are quite influential on the sonics.
Changing the coupling caps in the CD3 can be used to reduce resolution
and thus mask residual harshness from a digital source.
negativity?
yes, 100% negative feedback as a matter of fact....
impedance improvement?
well of course, tubes grids biased negative and not
allowed to draw current is indeed very high impedance,
in the megohms range so what is new?
input and output coupling caps are used here because the topology does not allow otherwise...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 29th September 2013, 02:53 AM   #125
Default Error, and I can't edit my own post?
Input
2x ESA 2.2uf
Output
4x SA .47uf
Should say:
Input:
2x ESA .22uf
Old 2nd October 2013, 06:30 AM   #126
Bernie7 is offline Bernie7  Singapore
Please note that even though film caps are "Non Polarized", the outside
of the foil should be used as a shield - which means it should be connected
to the low Z side of the circuit.
Hi Uunderhill
How do I tell which end is which on my Dayton film caps?
Dayton Audio DFFC-0.47 0.47uF 400V By-Pass Capacitor - Capacitors - Crossovers & Components - Loudspeaker Components
Old 23rd February 2014, 10:25 PM   #127
bladesmith is offline bladesmith  United States
Convert SD-CD3, to a 12volt external power source ?
(verses ac power.)
Wonder if it could be easily done, or not ?
Old 2nd February 2015, 12:11 AM   #128
tazzo is offline tazzo  United Kingdom
On what side are the positive and negative terminals for the .47uf and .22 caps? And can you elaborate plz Underhill? I do not know what you mean.
Old 2nd February 2015, 12:15 AM   #129
TonyTecson's Avatar
unless the caps were marked on the label which side is the inner foil and which is outer foil, then there is a 50-50 chance of getting it right....
in the old days, caps were marked which side is which, todays' botique caps seem to forget this practice....
Old 2nd February 2015, 01:29 AM   #130
enjoybiking is offline enjoybiking  United States
Default 12V operation of a CD3 or similar
(verses ac power.)
Sort of easy. 12Vdc to the 2 tubes heaters in series vs 6.3V x2, and then a Taylor Edge HPVS
Taylor Electronics Services HVPS
Faraday shield the top of the coil with copper foil tied to ground.
You can also "trick" that HVPS to go even higher with 12V input using a 7805 +5V shoved in one of the inputs, see attached.
Yaqin SD-CD3 Tube Buffer - upgrading capsHide this!Advertise here!
YAQIN SD-32A Tube CD/HDCD Player Rodango Digital Source 17 7th September 2017 05:48 AM
Yaqin SD-CD2 tube buffer - upgrading stock tubes JDawg Tubes / Valves 2 2nd September 2013 10:42 PM
Recommended upgrades for Yaqin Tube Buffer ? Galgo Tubes / Valves 5 4th July 2010 02:47 PM
schematic yaqin cd1 tube buffer asuservice Tubes / Valves 3 28th November 2009 12:36 PM
