| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Here's what I am doing. I have a 24 channel snake that is 24 input and 24/24 output. (in other words it splits with 24 going to the front of house mixer and then 24 going to a monitor mixer) Instead of having this bulky mixer and only one location for the musicians to go to for their monitor mix I have made a system using cat5 to distribute 24 channels of audio to eight different zones. Each zone can mix all 24 channels. Each musician now has the ability to mix their personal mix themselves at their station. I have all of the wiring, main module and individual mixing modules but I do not have a way to power the mics. I don't need phantom power just basic mics are being used like SM57s.
In a nutshell.....what should I do to accomplish making a simple 24 channel i/o mixer? I do not need anything like eq or panning. Thanks. |
#2 |
I guess what I can do is just use op-amps but I made a headphone amp a while back and used an LM386 and I got clear audio except the level of audio wasn't loud enough. If I pushed the audio it would begin to distort. So, in conjunction with my first question, what op-amp would I need to use for a mixer?
#3 | ||
#4 | |
The mics I am using are neodymium but while the do generate their own voltage having a preamp eliminates the hiss from the preamp on the headphone out. I guess I said that wrong. I don't need to power the mics because I am not using any type of condenser mics, but they do need the boost of a preamp in order to have the volume presence. I can't imagine in-line will work except on wireless mics.
#5 |
In making the above with a headphone out option is an op-amp all that is needed to give a powerful enough signal to the headphones?
Will something like this work? LME49710 - High Performance, High Fidelity Audio Operational Amplifier |
#6 |
Got a lot of info from this thread.
http://www.diyaudio.com/forums/headp...rix-mixer.html |
#7 |
On what op amps mixers use see this thread: Op amps help! 3x3 12v matrix mixer
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500 |
| Are there any DIP 24/96 or 24/192 ADCs and I2P to FireWire Codecs? | BoilermakerFan | Digital Source | 0 | 21st July 2008 08:27 PM |
| Soundcraft Studio 24 Mixer problem | jazzbee | Instruments and Amps | 18 | 19th February 2007 09:18 PM |
| schematic hillaudio 24/4/2 mixer | bill g | Instruments and Amps | 0 | 18th September 2006 03:54 AM |
| 2 X 660VA 24-0-24 toroid transformer for sale | onlylaputa | Swap Meet | 0 | 31st July 2005 09:29 AM |
| 24/96 and 24/192 is no good. MP3 sounds better! | peranders | Digital Source | 92 | 30th July 2002 09:30 AM |
| Page generated in 0.10461 seconds (70.82% PHP - 29.18% MySQL) with 10 queries |
